door panel on 1999 cherokee - JeepForum.com
post #1 of 6 Old 03-23-2007, 07:50 PM Thread Starter
jeep crazy
i want to upgrade the front speakers in my 1999 cherokee, does anyone know how to take the panel apart? or a link would be nice too.
thanks
jeep crazy is offline
post #2 of 6 Old 03-23-2007, 08:19 PM
black2door
black2door's Avatar
1994 XJ Cherokee
It pretty self explanatory. If you have cranks, the crank is held on with a little U clip thing that needs to be pushed out with something, pretty easy. There are like 4 screws and a bunch of little clips around the edges that hold it on. Then the door handle and lock rods are there tose are kinda tricky, you have to push the clip off of them, take a good hard look at um and you'll figure it out. After that there should be some wire discos to disco. ( I just let the door panel hang on the wires) Thats about it. Hope you get it.
black2door is offline
post #3 of 6 Old 03-24-2007, 01:35 PM Thread Starter
jeep crazy
i dont have cranks
post #4 of 6 Old 03-24-2007, 01:45 PM
inogenius
Originally Posted by jeep crazy
i dont have cranks
Even easier then. There's about 4 screws, one right at the arm rest, and then located around the door panel. Unscrew, massage a bit, and it should pop off. Before yanking, disconnect the two quick connects for the electrical stuff.
inogenius is offline
post #5 of 6 Old 03-24-2007, 08:19 PM
gregmondro
gregmondro's Avatar
5 screws and then you have to pull so that the plastic fasteners release (located around the door panel edges)
here's a pic, it's easy as pie. I just had to deal with this when my window regulator went out not too long ago.
- NP231, SYE, 4.56's, Rear D44 w/ Detroit SoftLocker and a RockCrusher Diff Cover, 35x12.5 BFG A/Ts, RE 5.5" XD Lift, Skidrow TC Skid, ORT Rear Bumper + Carrier, Rigidco Front Winch Bumper + Steering Box Plate, Milemarker 8000 Winch, Rock Sliders, HD Currie Steering, Control Arm Skids, Goferit Tie Rod Flip Insert, Optima Red Top and a few other goodies...
gregmondro is offline
post #6 of 6 Old 03-24-2007, 08:45 PM
bcrmartin
easiest route
just take out the one screw in the corner by the mirror, then pull out the plastic tabs just in the speaker area and the bottom of the door. then if you have a short screwdriver you should easily be able to pull the speaker while you pry out the panel. then if you break a plastic tab, you can get more at advanced auto. thats how i did it and it worked just fine.
bcrmartin is offline
1999 Cherokee Fuse Panel Diagram JeepQueen XJ Cherokee Technical Forum 8 Today 09:07 PM
96 Cherokee Door panel removal questions billabongopblue XJ Cherokee Technical Forum 6 05-25-2009 09:41 PM
Removing rear cup holder panels? 1999 2 door Cherokee Mikej1224 XJ/MJ Cherokee Non-Technical Forum 7 02-12-2009 10:56 AM
Removal of rear door panel--94 Cherokee Terryble XJ Cherokee Technical Forum 1 02-26-2007 02:01 PM
Stock number of speakers in 1999 Cherokee(4-door)? dcdude XJ Cherokee Technical Forum 3 03-11-2004 06:59 PM
