Dome lights - JeepForum.com
post #1 of 7 Old 05-09-2007, 04:22 PM Thread Starter
KellySimpson
Dome lights
I have a 91 cjerokee, I cant get my dome lights to turn off???? Help please ....
KellySimpson is offline
post #2 of 7 Old 05-09-2007, 04:30 PM
XJK
The Guru of Nothing
XJK's Avatar
pull the fuse....
-Kyle
It's Not Just a Jeep, It's a Lifestyle
XJK is offline
post #3 of 7 Old 05-09-2007, 05:18 PM
JeepFreak91
see if you headlight/dimmer switch is not on the "on" position for the interior lights
JeepFreak91 is offline
post #4 of 7 Old 05-09-2007, 05:54 PM
JohnnyEpic
1993 XJ Cherokee
I had the same problem. I've been without my lights for several months now. If anyone else knows what is up with this, it'd be really helpful. I know it's not the door ajar sensors and the dimmer isn't turned on.
1993 XJ 2 Door Country 4.0 Litre HO, AW4
Suspension: 3" Rough Country lift with full leaf packs and HD lower control arms | RE Gen2 Swaybar Quick Disconnects
Wheels & Tires: 31x10.50R15 BF Goodrich All-Terrain T/A KO | Cragar Black Soft 8's 15x8 4" BS
Recovery: Rock Lizard Rock Monitor Front Bumper | Drawtite Rear Hitch | Hi-Lift All Cast 48" | Hi-Lift Wheel Adapter
Lights: Four 6" Round 100 watt lights | Two rectangular backup lights | Two Hella 500FF lights on front bumper
Other: Surco 45x50 Sarari Rack | Tranny cooler | Smittybilt G.E.A.R. Seat Covers
Coming Soon: Detours USA Tailbone Tire-Carrier | AJ's Super Rock Rails
JohnnyEpic is offline
post #5 of 7 Old 05-09-2007, 05:57 PM
TwoOne
Check the dome light triggers to make sure they aren't heavily rusted which could cause them to be on full time. Just pull them out one by one and inspect them, if you're still not finding the problem pull all of the triggers out and off of their wires, then go through one by one and replace them verifying that your dome lights turn on and off by them. That should probably cure your problem, but if those don't do it check the one in the rear hatch for the same symptoms.
Louis
99 WJ Limited
TwoOne is offline
post #6 of 7 Old 05-09-2007, 08:36 PM
JohnnyEpic
1993 XJ Cherokee
Where's the rear hatch one. I have checked the doors and they're all ok. Nothing turns off the dome lights.
post #7 of 7 Old 05-09-2007, 11:43 PM
TwoOne
Rear hatch is triggered by the locking mechanism, if you take your rear cover off the inside of the hatch and look in at the lock there are a couple of wires coming off of the top of the latch, might check to make sure neither has rusted and fallen off and is contacting the other or something like that. I had about the same problem with mine, one of mine rusted off and fell down and it was contacting the locking rod everytime I shut the hatch and blowing my dome light fuse.
Louis
99 WJ Limited
TwoOne is offline
Goust dome lights??? Hussler XJ Cherokee Technical Forum 23 01-07-2010 06:26 PM
Dome Lights bajafanatic XJ Cherokee Technical Forum 2 10-05-2007 06:13 PM
dome lights jeeptorino68 XJ Cherokee Technical Forum 3 09-08-2006 12:14 AM
Gauge cluster lights don't come on unless dome lights are on as well. chevelle396 XJ Cherokee Technical Forum 0 08-15-2004 10:49 AM
Dome lights and such. madrabbitt XJ Cherokee Technical Forum 4 03-02-2004 11:15 PM
