Doin' My First Brake Job. Can I keep these rotors? - JeepForum.com
post #1 of 6 Old 05-16-2013, 01:17 PM Thread Starter
cavalier
So at speeds above 60 mph, if I hit the brakes, I get wheel shudder. This ain't optimal, so I took my wheels off. By the looks of em, the rotors look okay. What ya'll think? The vents (between the two surfaces) look pretty rusty, however. Thoughts?
cavalier is offline
post #2 of 6 Old 05-16-2013, 01:38 PM
its840
1994 XJ Cherokee
take them to autozone, advanced auto,oreilly or napa.. and ask them to turn them.. if they under spec they will let ya know.. should only charge about 10$ each rotor to turn..
when you replace pads you always want to turn or replace rotors at same time.
enjoy.
its840 is offline
post #3 of 6 Old 05-16-2013, 10:41 PM
RedRyderXJ
1994 XJ Cherokee
enjoy.
Yes. You need I have them turned when replacing the brakes
RedRyderXJ is offline
post #4 of 6 Old 05-17-2013, 05:27 AM
Azzy
enjoy.
Its actually hard around here to find a place that will turn rotors, and it wasnt $10 last time I found a place to do it. More like $30 a wheel. (pep boys)
Im the guy who makes new gauges, check out our gallery at Teamadw.com
Azzy is offline
post #5 of 6 Old 05-17-2013, 01:24 PM
AZ Jeff
2014 JK Wrangler
The rotor face looks good in the picture. HOWEVER....rotor FLATNESS is what will determine if you continue to have brake shudder. That can be checked by two ways:
1. using a runout guage on the vehicle
2. taking the rotors to a machine shop and asking them if they can be turned flat within spec.
AZ-Jeff
I don't own an XJ any longer, but I still think they are the best of all the Jeep products ever made. My XJ was my favorite vehicle in my 50+ years of driving.
So...I stick around and give advice.
AZ Jeff is offline
post #6 of 6 Old 06-05-2013, 09:40 AM
greenlawnjeeper
I gave up having rotors "turned" years ago and decided to put the $$$ toward new ones - which really aren't that much considering the importance of brakes.
'96 Cherokee Country, Magnaflow cat and Borla exhaust, Hella 550's, Up Country suspension, Michelin MS 2's in 235x15 and Edelbrock IAS shocks. 91K orig. miles - the wife uses it ('cept when I borrow it to go huntin').
greenlawnjeeper is offline
