Does code 14 (MAP sensor) match the problems Im having? - JeepForum.com
post #1 of 15 Old 04-04-2012, 11:04 PM Thread Starter
Gutz88
1997 XJ Cherokee
This is my first Jeep. 97 Cherokee Sport with 150,000 miles. I got it as something to fix up. Wasn’t running when I bought it. It was missing the following parts I put in. But in new fuel pump, fuel filter, alternator, starter, spark plugs-wires-cap-rotor, radiator, thermostat, intake manifold, throttle body, battery and tires. It runs now put having issues. When I start it idles high 2500-3000 for 20 seconds or so then drops down to around 1000, it’s hard to start I have to give it gas while starting, exhaust smells strong, hesitates when I accelerate, sometimes it stalls while idling (but rarely stalls after a couple minutes of running) . BUT when I get to about 40+ mph it runs dam good as long as I don’t accelerate hard! Code 14 shows up (MAP sensor). SO does all that happen when a MAP sensor is bad?? Ive spent a lot of money already so just want to see what’s the issue before I spend more.
OH, sorry forgot one. My catalytic converter is also bad. I bought a new one just haven’t had the time to put it on.
THANKS
Gutz88 is offline
post #2 of 15 Old 04-04-2012, 11:31 PM
robsjeepxj
I would tend to believe the code is correct, replace anything indicated first then if nothing changes I'd say unbolt the cat and see if that helps.
robsjeepxj is offline
post #3 of 15 Old 04-05-2012, 12:14 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Your Cherokee has OBD-II self diagnostics, you should use it. Download the four digit Pxxxx Check Engine Light trouble codes with a code reading device and either do a Google search or post them here. OBD-II trouble codes are much more specific about the problem and make your troubleshooting easier.
CJ7-Tim is offline
post #4 of 15 Old 04-06-2012, 09:40 PM Thread Starter
Gutz88
1997 XJ Cherokee
Well I just ordered a MAP sensor and an OBD-II code reader off ebay... Hope its just the MAP cause it was cheap.. Thanks
Gutz88 is offline
post #5 of 15 Old 04-06-2012, 11:26 PM
Reptile
1991 XJ Cherokee
YES. MAP sensor is one of the primary suspects for eratic idle. And if throws a code for it then it pretty much narrows it down. But it doesn't necessarily means it's bad. First check your vac hose going to the MAP, it may be cracked or simply disconnected.
Reptile is offline
post #6 of 15 Old 04-07-2012, 12:31 AM Thread Starter
Gutz88
1997 XJ Cherokee
Yea just check the vac hose, its good. I didn’t even try this before but I just unplugged the MAP and the dam thing started right up.. It ran rich but it started! Plugged it back up and doesn’t start unless I give it gas.. Well new MAP will be in soon. Ill post the results of the new map when I get it.. Thanks
Its weird cause the MAP sensor in there now looks dam new..
Gutz88 is offline
post #7 of 15 Old 04-07-2012, 05:56 AM
tjwalker
It's the crank sensor!
tjwalker's Avatar
Beware of any and all engine management sensors from ebay UNLESS the brand name is confirmed.
There are a ton of cheap-charly sensors available on ebay; some work for a while then puke out, some don't even work out of the box.
99 Cherokee, 4.0 AW4, NP242
Past Jeeps: 49 Willys, 81 Scrambler, 88 Comanche
Without "data", all you have is an opinion!
tjwalker is offline
post #8 of 15 Old 04-07-2012, 06:45 AM
robsjeepxj
Dealer sensors will definitely be a much safer bet.
post #9 of 15 Old 04-07-2012, 07:17 AM
tjwalker
tjwalker's Avatar
Agreed. I buy plenty of aftermarket parts. Engine management sensors aren't on that list.
tjwalker is offline
post #10 of 15 Old 04-09-2012, 07:58 PM Thread Starter
Gutz88
1997 XJ Cherokee
Ok installed the new map sensor oday and still having issues... I have to give it alot of gas to start... But it doesnt idle as high now tho and when i get up to about 25mph it drives great.. I guess its something else too.. I think i should look at the TB tomorrow... Maybe i installed it wrong???
Gutz88 is offline
post #11 of 15 Old 04-09-2012, 08:00 PM Thread Starter
Gutz88
1997 XJ Cherokee
The way im going this whole Jeep is gonna be new by time im done and broke!
Gutz88 is offline
post #12 of 15 Old 04-10-2012, 01:13 AM
Reptile
1991 XJ Cherokee
Could be a bad part, as TJ said, lots of aftermarket junk out there. And your chances of getting one of those... pretty good.
If you don't want to spend the money on a quality OEM part, go to the junkyard, nowadays you're more likely to get a sensor in operating condition there than with aftermarket parts. And for what they cost at the jy, pull two of them from two different Jeeps to double your chances.
Now there is also a procedure to test the MAP if you have a voltmeter.
Reptile is offline
post #13 of 15 Old 04-11-2012, 11:12 PM Thread Starter
Gutz88
1997 XJ Cherokee
Found IT!!!!
Gutz88 is offline
post #14 of 15 Old 04-11-2012, 11:14 PM Thread Starter
Gutz88
1997 XJ Cherokee
dam pics wont show
Gutz88 is offline
post #15 of 15 Old 04-11-2012, 11:18 PM Thread Starter
Gutz88
1997 XJ Cherokee
Uploaded with ImageShack.us
Gutz88 is offline
idling , MAP sensor
Code P0138 high voltage code, Bank 1 sensor 2? crmaverick89 XJ Cherokee Technical Forum 20 03-16-2013 07:04 PM
Code 21 - O2 sensor 1996BlackXJ XJ Cherokee Technical Forum 1 03-19-2009 08:12 PM
MAP sensor code on 98 4.0 csfiend XJ Cherokee Technical Forum 2 10-24-2007 05:45 PM
O2 Sensor Code 21 Help ben2 XJ Cherokee Technical Forum 1 04-24-2007 10:21 PM
O2 sensor/s and the 21 code LilgreenXJ XJ Cherokee Technical Forum 2 12-05-2006 08:26 PM
