does anyone need help with the power steering pump? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ Cherokee Technical Forum > does anyone need help with the power steering pump?
Rear Disc Brake Conversion Kit- TJ,YJ,XJSWAG 50 Cal Ammo Can Mount With M2A1 Can~Artec JK 1 TON SWAP~
Unread 07-10-2014, 10:01 PM   #1
joekillz
1995 XJ Cherokee
I have a 1995 jeep cherokee 2.5L 5 speed. it came with the power steering pump that has the reservoir next to the radiator. I read on here that these reservoir always leak. The one on my jeep was leaking so i decided to swap it with one that has the reservoir on the actual ps pump. i got it from a grand cherokee but ive also seen them on the 6cyl xj's. Put it in this morning and it works perfectly fine and looks way better. Also give you a bit more space (not like you need it) instead of all those hoses and the reservoir/bracket. Hope this helps someone
joekillz is offline   Reply With Quote
