Does 1989 cherokee xj have a fuel pump fuse? - JeepForum.com
post #1 of 7 Old 09-10-2010, 07:38 PM Thread Starter
bigislandhikers
1989 XJ Cherokee
Relay seems to be ok. While changing filter verified that the pump doesn't work. Before changing out the pump I want to make sure there are no fuses that could be bad.
Thanks
bigislandhikers is offline
post #2 of 7 Old 09-10-2010, 08:08 PM
CKUPQ
sounds like your ballast resistor died. I can't remember where its at but its a little chunk of porcelain on the fender that is inline with the relay.
Either our language or our culture needs to be expanded/improved so that there is a polite way to say:
Stop talking now, because I am going to stop listening.
99 XJ 3" Rusty's coils DT3000 front shocks, 3" S-10 bastard back, Homemade T-case drop, recovery points front and rear.
CKUPQ is offline
post #3 of 7 Old 09-11-2010, 10:07 AM Thread Starter
bigislandhikers
1989 XJ Cherokee
Would the ballist resister effect the fuel pump? Isn't the pump 12v?
Mine is cracked, but it has been since I bought the jeep. Wasn't sure what it was for.
Thanks
BIH
post #4 of 7 Old 09-11-2010, 01:40 PM
CKUPQ
The ballast resistor is in-line with the pump. Its sole reason is to keep the pump "quieter". If you by-pass it you'll actually be doing yourself a favor because the pump will then be seeing 12V instead of 10 or 11V
Cliff notes: Remove it, it won't hurt your pump.
CKUPQ is offline
post #5 of 7 Old 09-11-2010, 03:01 PM Thread Starter
bigislandhikers
1989 XJ Cherokee
I have the old pump out. Can I hook it up to the battery to see it it works before I install the new one. If so which wire on the pump goes to positive and negative.
Thanks
BIH
post #6 of 7 Old 09-11-2010, 03:30 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
You can, but remember what sparks and gasoline can do when combined. Check your ballast resistor for continuity while you're at it.
cruiser54 is offline
post #7 of 7 Old 09-12-2010, 12:20 AM
compfreak530
The ballast resistor is bypassed during first ignition.. so if the pump isnt comming on even during cranking its probly a bad pump. with the pump in hand just apply power to the two terminals. try both ways. wont hurt. if pump dosent come on then its bad. the ballast resistor is there to prolong the life of the pump by lowering the voltage to it. it dosent need to be at full power to supply more then enough juice to the engine.
compfreak530 is offline
1989 4.0L Cherokee belt replacement and water pump questions Cherokee_Kid XJ Cherokee Technical Forum 18 11-22-2015 04:08 PM
Regarding Fuel Pump Fuse bludragon88cher XJ Cherokee Technical Forum 3 11-17-2009 06:36 PM
Where is the wiper fuse / relay on a 1989 Cherokee abovenbeyond XJ Cherokee Technical Forum 3 07-11-2008 11:26 PM
Fuse for fuel pump? Will9879 MJ Comanche Technical Forum 0 05-10-2008 03:19 PM
1989 Cherokee blows blower fuse 98crewcab XJ Cherokee Technical Forum 1 11-05-2006 12:04 AM
