Do I need a new front and rear drive shaft w/ a SYE kit - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Do I need a new front and rear drive shaft w/ a SYE kit
Poison Spyder DeFenders™ - "Tubeless" Jeep FendePoison Spyder Dana 44 Bombshells Are BACK!!Poison Spyder RockBrawler II Rear Bumper with Tire Carrier
Unread 02-13-2010, 05:48 PM   #1
whiteys_red_XJ
Hi which drive shaft do I replace when I put an SYE kit and new driveshaft. Do I have to get a new FRONT and REAR driveshaft O and I have a 96 Cherokee xj auto and a np 242 T-case. ask because I was doing some research and some companys say that it comes with a new rear shaft but others say comes with a new front shaft
96 xj 3.5 rustys lift, 33x10.50x15 BFG MT, t case skid plate, front tow hooks, open front and rear diff, NP-242 T-Case 1 in drop, AW4 transmission, dana 30HP, chyrsler 8.25 stock gears, K&N drop in air filter, flowmaster 40 series, poweraid throtle body spacer
whiteys_red_XJ is offline   Reply With Quote
Unread 02-13-2010, 05:52 PM   #2
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
http://www.jeepforum.com/forum/f11/t...ks-tsbs-89273/
Contains answers to every question in the XJ world.
Progressive Liberalism: Bringing you new ideas so wonderful, they have to include mandatory participation ......
Originally Posted by Ronald W. Reagan
Government is not the solution to our problem; Government is the problem.
CJ7-Tim is offline   Reply With Quote
Unread 02-13-2010, 06:32 PM   #3
xjfever
1995 XJ Cherokee
The rear driveshaft is the one you will be replacing. You replace it with a double cardan driveshaft like the front shaft. Some SYE's allow the use of a stock front driveshaft in the rear. If you look at the two in comparison the rear has a single u-joint at each end and a slip yoke on the t-case end which allows movement of the driveline without binding. The front shaft has a single u-joint at the axle end but two u-joints at the t-case end and a slip joint in the middle section of the shaft. The double cardan shaft can tolerate greater angles without causing vibrations. Hope that helps.
  2. '99 WJ limited, 4.7L, 3" IRO lift. Bilstein shocks, JK rubicon wheels, 255/70/17's, carolina driveshaft, IRO adjustable control arms, IRO adjustable A-arm
xjfever is offline   Reply With Quote
Unread 02-13-2010, 07:37 PM   #4
whiteys_red_XJ
That does help alot . So could I take the front driveshaft out of a junkyard and use that as the rear drive shaft wit the sye kit?
Unread 02-14-2010, 05:30 AM   #5
xjfever
1995 XJ Cherokee
Yes. That is what a lot of people do.
Unread 02-14-2010, 05:51 AM   #6
whiteys_red_XJ
Thanks bro you just saved me like 200$ on buying a new one I'm going to do that and just replace all the joints
96 cherokee xj , auto , np 242 , sye kits
