Do i need an alignment after replaceing my Front Control Arm bushings? - JeepForum.com
post #1 of 4 Old 12-28-2008, 10:58 PM Thread Starter
aleebee156
1997 XJ Cherokee
Hey guys, i just replaced my front control arm bushings. do i need to get an alignment? it seems to drive just fine. let me know what you think, i keep hearing mixed thoughts.
aleebee156 is offline
post #2 of 4 Old 12-28-2008, 11:36 PM
urbex
Any time you replace parts in the front end, it's a good idea to get the alignment checked. Assuming the rest of the parts are in good condition, and the alignment wasn't off before you replaced the bushings, technically you're not changing anything that would alter the alignment just by replacing the CA bushings.
urbex is offline
post #3 of 4 Old 12-29-2008, 09:54 AM
AZ Jeff
2014 JK Wrangler
Your suggestion assumes, of course, that the vehicle was never re-aligned with worn control arm bushings. Unless the OP is the original owner we won't know for sure.
Owing to that, your first bit of advice is best---ALWAYS realign the front end when installing new suspension parts.
AZ-Jeff
I don't own an XJ any longer, but I still think they are the best of all the Jeep products ever made. My XJ was my favorite vehicle in my 50+ years of driving.
So...I stick around and give advice.
AZ Jeff is offline
post #4 of 4 Old 12-29-2008, 05:51 PM Thread Starter
aleebee156
1997 XJ Cherokee
thanks guys, im getting it aligned tomorrow morning.
Front stock suspension issues (control arm bushings) sebastian22 XJ Cherokee Technical Forum 20 10-22-2009 12:35 PM
Guys That Replaced the Front Control Arm Bushings In Here gtospeeding XJ Cherokee Technical Forum 26 10-20-2009 07:51 AM
Front Control Arm Bushings: Bad? midfat XJ Cherokee Technical Forum 15 02-27-2009 07:31 PM
Dana 30 Front Upper Control Arm Bushings LEAD_NOT_FOLLOW XJ Cherokee Technical Forum 10 06-11-2007 03:45 PM
replaceing stock control arms (any trick to it?) my88'xj XJ Cherokee Technical Forum 3 10-30-2006 10:47 AM
