Do I have the np231 Transfer Case? - JeepForum.com
post #1 of 4 Old 09-19-2011, 11:23 AM Thread Starter
SteeSin
I have a '98 Jeep Cherokee Classic 4.0L 6cylinder Automatic Transmission. I've been saving up for the 6.5" Rough Country X-Series Lift kit. They recommend the SYE and rear ext driveshaft. To get that they say you NEED to have the np231 transfer case. Can someone let me know that transfer case is already on my XJ model? Thank you
SteeSin is offline
post #2 of 4 Old 09-19-2011, 11:26 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Crawl under and look at the ID tag on the T-case or look at your 4x4 shifter bezel.
NP 231 has no FULL-TIME position.
NP 242 has FULL-TIME position
CJ7-Tim is offline
post #3 of 4 Old 09-20-2011, 01:30 AM Thread Starter
SteeSin
I have the one to the left thanks, should be lifting my first jeep soon!
SteeSin is offline
post #4 of 4 Old 09-20-2011, 02:29 AM
Timo_90xj
Timo_90xj's Avatar
Originally Posted by SteeSin View Post
...Rough Country X-Series Lift kit. They recommend the SYE and rear ext driveshaft. To get that they say you NEED to have the np231 transfer case. Can someone let me know that transfer case is already on my XJ model? Thank you
..and they are full of crap with the above statement. One can get a hack 'n tap SYE for the 242 (full time case), and use a double cardan joint rear DS.
But you have the 231 which has way more aftermarket support and you can get a true HD SYE kit for it. 231 is also slightly stronger than 242
***Under construction***
Timo_90xj is online now
transfer case np231 behind AX-15?? bamajeepjunkie XJ Cherokee Technical Forum 4 10-24-2009 11:51 PM
NP231 Transfer case popping upon engaging XJride231 XJ Cherokee Technical Forum 20 09-09-2009 05:24 PM
Transfer Case Confusion (NP231) HELP! skipshotMJ MJ Comanche Technical Forum 1 07-02-2009 01:33 AM
Switch transfer case from NP231 to NP242 louisd11 XJ Cherokee Technical Forum 11 11-18-2007 11:27 AM
Dex Merc III in NP231 Transfer Case? 5point9Limited XJ Cherokee Technical Forum 7 03-04-2007 05:53 AM
