Do cherokees have a serpentine belt tensioner? - JeepForum.com
post #1 of 21 Old 02-07-2013, 01:01 PM Thread Starter
SteeSin
Ive been trying to find auto parts stores local and online and nobody carries a ''Serpentine belt tensioner'' and online i get 0 results, only thing that comes up is a idler pulley. For the problem im having ive been told i need a tensioner but cant find it anywhere and i need it asap because i cant drive my jeep because I think the belt isnt spinning the alternator and it drained my battery all the way, the gauge for the battery stayed all the way down. I know you can tighten it but last time i had a mechanic look at it they put a new belt in because it was squeaking then said its still gonna squeak because the tensioner is bad... but then again how come i cant find this part anywhere???
SteeSin is offline
post #2 of 21 Old 02-07-2013, 01:12 PM
slickfreeze
1995 XJ Cherokee
there is no tensioner, the belt is tightened from the power steering pump bracket. there is an idler pulley, but it does not effect the tension. If the idler pulley is bad, it will create squeaking noises. start it up and look under the hood and see if the alt. is turning. you might just have a bad alt.
________oooo
//__l_l_,\____\,_____
l_/-\_l__l_/-\_|[]lllll[]|
_\_/==== |; _\\ \\
_(o)_)___(o)_)--o-)_)
"ask not what your country can do for you; ask what you can do for your country." John F. Kennedy
slickfreeze is offline
post #3 of 21 Old 02-07-2013, 01:21 PM Thread Starter
SteeSin
I did an alternator test and that came up fine
SteeSin is offline
post #4 of 21 Old 02-07-2013, 01:23 PM Thread Starter
SteeSin
i dont get what i have to replace
SteeSin is offline
post #5 of 21 Old 02-07-2013, 01:24 PM Thread Starter
SteeSin
and it was squeaking before and after the new belt was replaced, so would the idler pulley affect the alternator working?
SteeSin is offline
post #6 of 21 Old 02-07-2013, 01:26 PM
Jakobi
How did you test the alternator?
-Jake
"Flying is easy, all you have to do is throw yourself at the ground and miss."
-Douglas Adams
Jakobi is offline
post #7 of 21 Old 02-07-2013, 01:29 PM
slickfreeze
1995 XJ Cherokee
press on the belt, (when the vehicle is turned off) it shouldnt really move. I cant remember the exact deflection but it isnt much. Its supposed to feel pretty solid. if its loose all ya gotta do is tighten it from the power steering pump. you can find lots of threads on how to tighten the belt. Its a pretty easy process. NAPA sells a gauge you can use if you wanna get the tension exact.
________oooo
_\_/==== |; _\\ \\
post #8 of 21 Old 02-07-2013, 01:33 PM Thread Starter
SteeSin
It's very loose I think because I was able to twist it quarter of the way
SteeSin is offline
post #9 of 21 Old 02-07-2013, 01:50 PM
slickfreeze
1995 XJ Cherokee
That actually sounds about right, mine twists about a quarter. Im thinking you have two problems. is the noise you hear more of a squeak or a squeal? is it constant or just when u turn on the A/C or something? How did you have the alt. tested? im betting the belt isnt the issue as to why your alt has no output. if the belt was too loose to turn the alt. i would imagine it would be too loose to turn the water pump and power steering pump.
________oooo
_\_/==== |; _\\ \\
post #10 of 21 Old 02-07-2013, 02:44 PM
sAe23
1995 XJ Cherokee
You need a new mechanic.
As Slickfreeze has pointed out, the power steering pump is the "tensioner" for the belt.
Loosen the bolts for the PS pump and move it and you should get the basic idea...
sAe23 is offline
post #11 of 21 Old 02-07-2013, 03:31 PM
MJR
MJR's Avatar
1988
The power steering pump is the adjustment on 87-95 models, the 96-01 use an idler for adjustment.
"Got Groceries"
88 Jeep Wagoneer
MJR is offline
post #12 of 21 Old 02-07-2013, 05:08 PM
slickfreeze
1995 XJ Cherokee
thats a good point! I forgot they changed it on the newer body style! I found this little thread that shows a pretty good picture of how to adjust the newer style tensioners. Its actually even easier than the old power steering pump style
http://www.jeepforum.com/forum/f11/s...aling-1161327/
________oooo
_\_/==== |; _\\ \\
post #13 of 21 Old 02-07-2013, 05:22 PM
MJR
MJR's Avatar
1988
One year before.
"Got Groceries"
88 Jeep Wagoneer
MJR is offline
post #14 of 21 Old 02-07-2013, 05:28 PM
slickfreeze
1995 XJ Cherokee
One year before.
the 96's dont count, they are the bastard child between the new and the old haha
________oooo
_\_/==== |; _\\ \\
post #15 of 21 Old 02-07-2013, 07:21 PM Thread Starter
SteeSin
Thanks guys
SteeSin is offline
