DIY long arm kit! - JeepForum.com
post #1 of 19 Old 02-09-2013, 01:43 AM Thread Starter
DoctorTim
DIY long arm kit!
Im getting used to the fact that everything is freaking expensive. College student with not a lot of money.. Ive already build my own bumpers and a dashboard so i thought i would take my fabrication skills to the next level. just got done designing this. will work on the rest tomorow. let me know on your thoughts. Should I beef up the crossmember? everything is 1/4" but the tubing is 1.5x1.5x0.125. As for the linkage, im using either 1.75" or 2" DOM with 1/4" walls, johnny joints at the frame, and eurathane double sheer at the axle.
96 XJ, geared, 8.8, 5", 33s, dash
DoctorTim is offline
post #2 of 19 Old 02-09-2013, 05:04 AM
DNFJ
Looks good but you should probably plate or grate that open space off the center, would hate for a rock to use that space to wedge in there and hit the tranny or tcase.
'00 XJ Locked on 35s
Previous:
'00 TJ 2" on 33" Grabbers
'00 XJ 6.5" on 35" KM2s
'96 ZJ 2" on 31" Baja Claws
'93 ZJ - Stock, Totaled
DNFJ is offline
post #3 of 19 Old 02-09-2013, 05:23 AM
MGDWJ
I would also make it a 3 piece design kinda like Clayton's
MGDWJ is offline
post #4 of 19 Old 02-09-2013, 08:43 AM
haloperformance
1991 XJ Cherokee
To my novice fabricator(at best) eye, that design looks good. Ive got a 3 link Rockkrawler with Johnnys at the axle and frame... iv been thinking of switching the frame side to bushngs because the tide is LOUD when the suspension moves. Is there a reason you are putting bushings of the axle? I'm not questioning your design... just wondering if your idea will work better for me than my idea!
91 XJ: 35"s, 4:56s 5"LA lift 3"stretch, locked, skids, cage, high steer, spray paint.
98 XJ: Stock
haloperformance is offline
post #5 of 19 Old 02-09-2013, 10:44 AM
Timo_90xj
Timo_90xj's Avatar
Since you're going this far with your build and doing it yourself, do yourself a favor: do a bit more research on front 3- link + panhard designs, go to pirate and search for 3-link calculator (excel- based thingy that allows you to design a proeprly working TRUE 3- link). Although radius arms are easier to do than 3-link, 3-link system works a lot better than radius arms. It isn't rocket science, and there are plenty of readily available designs if you browse through the Cherokee section on Pirate.
Other than that, IMO that crossmemeber looks pretty good. As mentioned, plate the area between the tubes, don't leave it open. Make it as level as possible with the uniframe rails, and fab/ buy frame stiffeners. Your XJ unibody will love 'em
***Under construction***
Timo_90xj is online now
post #6 of 19 Old 02-09-2013, 11:05 AM Thread Starter
DoctorTim
it is, you see the 3 holes one each side? thats where center bolts onto the brackets
not sure why, i looked at my neighbors setup from rubicon express on his JK. thats how they made it.
its just dificult for me to see how a third link could fit in there. on ones side i have the driveshaft in the way, and the other side i have the exhaust in the way...?
as for frame stiffeners, i want to make my own, should i get tubing, or plate it? i've seen some kits which are made out of tubing. or should i just plate it with 1/8", 3/16", 1/4"? This is my daily driver, want to keep the weight a bit lower for some precious MPG.
post #7 of 19 Old 02-09-2013, 01:42 PM
Timo_90xj
Timo_90xj's Avatar
Exhaust can be rerouted Running true 3-link usually does involve a bit more work, and you normally need to cut through the floor on the passenger side for the frame-end link mount to fit high enough. It's not a big cut and can be covered with sheetmetal. Even though your XJ is your DD, the upper link notch on the floor can be cut & covered so it looks good and doesn't really eat away passenger legroom.
Radius arms are definitely easier to fab and can be made to work ok with good shocks, but it'll always have the known issues no matter what - brake dive and front unloading on steep climbs. A lot of off-road vehicles are built this way (all coil- sprung live axle Toyotas, Land Rover Defender/ Discovery, Range Rover, G- class Merc, etc...), and it works. But it binds more than 3- link, and is not the ideal way to build a front suspension. Jeep came pretty damn close on building the perfect front suspension (4-link + panhard bar), but they cheaped out on running too short arms built from thin sheetmetal Check for 3-link on Pirate4x4 Cherokee section, and then diceide which way you wanna go... 3-link design ain't that hard, but expect spending a couple of days studying/ researching on 3-link/ 4-link theory and getting the link setup right. If you're not ready for that, fab radius arms
Frame stiffeners aren't actually that expensive, and IMO the amount of work you do fabbing your own (cutting, bending, drilling a lot of rosette- weld holes, making everything fit) it's probably worth it to buy a set from a known good manufacturer. 1/8" works if done right (= enough rosette welds, stich- welding the upper seam, wrapping the stiffeners all around the uniframe rails), 3/16" is bulletproof, 1/4" is overkill if you ask me.
post #8 of 19 Old 02-10-2013, 12:13 AM Thread Starter
DoctorTim
updated design. crossmember is 3/16"
probably still doing radius arm, dont want to deal with 3-link buisness.
post #9 of 19 Old 02-10-2013, 06:46 AM
cbenez1
Following
A nation that forgets it's defenders will itself be forgotten
01 Up Country 6.5 long arm
cbenez1 is offline
post #10 of 19 Old 02-10-2013, 08:59 AM
RedRyderXJ
1994 XJ Cherokee
I like so far
RedRyderXJ is offline
post #11 of 19 Old 02-10-2013, 06:52 PM Thread Starter
DoctorTim
all done, what you think?
****ing solidworks....
post #12 of 19 Old 02-10-2013, 08:51 PM Thread Starter
DoctorTim
well solidworks doesn't have an option for something that would recreate a rubber bushing so it doesn't allow me to move the axle up and down like it normally would as you can see.. rubber bushings are made te squish in different directions a bit, which is why a radius arm doesn't work on solidworks, but it works in hte real world.
post #13 of 19 Old 02-10-2013, 09:07 PM
Starboard M
If you are set on a radius arm, at least put the lower mounts even with the frame rails. No sense in having them hang down that low if you are making this thing from scratch.
Are these mounts going to be welded or bolted on?
Originally Posted by NoVaHunter View Post
Honestly, its dicks like you that make unnecessary comments via the internet that have no impact what so ever.
Starboard M is offline
post #14 of 19 Old 02-10-2013, 09:38 PM
Hussler
1992 XJ Cherokee
I would go a little deeper on the overlap of that three piece design. Also, those bent up tabs where those horizontal bolts would go arent really doing much because those flanges dont extend over the links. Also a t case skid.
You mentioned the exhaust, be careful moving it too close to the floor, you will melt the carpet lol. When I made my crossmember I lifted the exhaust system 2 inches, that started melting the carpet. I ended up cutting out the passenger side floor and raising it an 1 1/2 and made an aluminum heat shield. But damn do i have clearance.
Also def plate the frame, I used some kit from online it was like 175, way worth the cost vs. time.
Originally Posted by chris87xj View Post
Sometimes a restoration project is a labor of love, at which point cost, time, and labor involved become irrelevant.
Originally Posted by BorderC View Post
I see you also twizzled your scart lead. Well done! :thumbsup:
92 XJ with ARB's, 5" lift, too much armor, 33's and some other garbage
Hussler is offline
post #15 of 19 Old 02-10-2013, 09:50 PM Thread Starter
DoctorTim
well im considering a 3-link+panhard seeing how it may actually be easier to make, i did some more research and found that if you make all arms somewhat parallel you get really nice travel. before i commit i need to find out how to re-route my exhaust, thats my only barrier. and i will be welding on new axle mounts. and repositioning the frame mounts more inward. Eventually took Timo's advice haha!
