Distributor Timing help needed, 1999 Cherokee - JeepForum.com
post #1 of 7 Old 06-26-2008, 06:27 PM Thread Starter
99cherokee
So I sold my past Cherokee and I just got another one.
My new is a 1999 4.0l 5 speed, 4wd.
With a 134,000 and it was starting to run a little rough so I removed the distributor cap and rotor and bought new ones and while replacing them the little 7mm bolts snapped on me, cause I don't think the cap was ever changed and wonderful Buffalo, NY winters do wonders on bolts.
So anyways I then removed the whole distributor from the Jeep so I could drill out the holes.
I am going to put it back in and realized I never marked what the timing was when I took it out.
SO my question is how do I put it back in, is there anyway to know where to line up the teeth so that the timing will be on?
Any help will be appreciated as I am doing this right now!
thanks
Brad
If you're into cars you must understand the golden rule: You have 3 words: Fast, Cheap, Reliable...
The problem is, you can only choose 2 of them.
99cherokee is offline
post #2 of 7 Old 06-26-2008, 06:30 PM
balloo93
Little Red Menace
balloo93's Avatar
1993 XJ Cherokee
Remove the #1 spark plug. Put your finger over the hole the spark plug went to. Have someone bump the ign over in short bumps and stop when the air forces your finger off the hole.
Install the dist making sure the rotor lines up with the #1 spark plug terminal ON THE CAP. You may have to index it counter clockwise a little and set the dist in. When the gear meshes it will rotate it into postion.
93 Sport
Beer is proof that God loves us and wants us to be happy............Ben Franklin
Specs in Profile.
balloo93 is offline
post #3 of 7 Old 06-26-2008, 06:45 PM Thread Starter
99cherokee
Is spark plug #1 all the way to the header panel side or all the way to the firewall side?
post #4 of 7 Old 06-26-2008, 06:48 PM
balloo93
Little Red Menace
balloo93's Avatar
1993 XJ Cherokee
#1 is the closest to the radiator and then it's 2,3,4, ect till you hit the firewall.
93 Sport
Specs in Profile.
balloo93 is offline
post #5 of 7 Old 06-26-2008, 09:57 PM
eliassami5
1991 XJ Cherokee
dead timing is a b***h..50/50 chance of getting it right, when your finger blows off the hole you might wanna look down the the main pulley and see if the TDC or top dead center line is lined up with the mark directly above the pulley...most likely it wont be unless you are really lucky. i dunno if you can get a wrench down there or not with the rad still in but turn the pulley backwards or forwards as needed to line up the marks, careful not to loosen the bolt when turning counter clockwise.
remove the dist cap and turn the rotor inside to line up with the number one ignition point on the cap..it should be marked by the number 1 on the cap, then drop it in where it feels right (that means there you have the most clearance for you to get to the bolt caps), it wont fit right the first time so you have to turn the dist counter clockwise to "index" it as balloo said it then drop it in and it will rotate itself and fit in.
I no i prob made no sence lol but its kinda a hands on job and you have to see it to know what to do..but hopefully that'll help. I would just take it to a mechanic shop and have em do it insted of doing it wrong and having it backfire like hell.
eliassami5 is offline
post #6 of 7 Old 06-26-2008, 11:57 PM
firefighter1c57
SPACE FOR RENT
firefighter1c57's Avatar
I'll add that there is a hole in the bottom of the distributor, and a matching hole in the stator, you'll have to pull the pickup coil to see it. I used a allen wrench, but you have to line the holes up before you stab the distributor. Then the ears have to be lined up with the bolt holes, you'll see what I mean. Now, with all those things lined up, the rotor then has to point to number 1 plug wire, other wise you'll get hall effect.
I bring NOTHING to the table.
firefighter1c57 is offline
post #7 of 7 Old 06-28-2008, 03:32 PM Thread Starter
99cherokee
Question what is hall effect?
tried everything above and still won't start..... any thing I could be missing
Adjustable distributor timing Gsmyth75 XJ Cherokee Technical Forum 7 04-26-2009 11:26 AM
Adjusting Distributor Timing - Need info eliassami5 XJ Cherokee Technical Forum 3 09-29-2008 10:26 PM
1999 Cherokee parts needed. 92Jeepguy XJ Cherokee Technical Forum 7 01-22-2008 03:49 PM
Distributor timing questions xjman4life XJ Cherokee Technical Forum 7 01-16-2007 12:36 PM
Distributor Timing HELP cherokee5up XJ Cherokee Technical Forum 3 12-07-2006 06:51 PM
