Distributor Protector?? - JeepForum.com
post #1 of 5 Old 03-11-2010, 12:17 AM Thread Starter
doomgoon
1990 XJ Cherokee
Is there a way I can prevent mud and water from splashing onto the Distributor or at least block it? I need an idea because every time I go in the mud it gets soaked and my Jeep drives super slow.
doomgoon is offline
post #2 of 5 Old 03-11-2010, 12:45 AM
Timo_90xj
Timo_90xj's Avatar
1. Remove cap
2. Get out tube of silicone and your silicone gun
3. Apply a bead of silicone on the edge of the cap
4. Re-install cap
That's what a lot of guys do here who loves wheeling in mud. Make sure you also block the cap vent hole with the silicone.
The downside is, over time water will condense inside the distributor, which causes corrotion and the exact same symptoms you're having now. But it isn't a huge pain to remove the cap every now and then and wipe it clean and check for corroded cap and rotor contact points.
***Under construction***
Timo_90xj is online now
post #3 of 5 Old 03-11-2010, 12:49 AM
PlatinumNiner
Heavy ziploc bag and a rubber band or two every time you go wheeling.
PlatinumNiner is offline
post #4 of 5 Old 03-11-2010, 04:55 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Maybe a surgical glove with small holes cut in the fingertips for the wires to go through. You could call it your distributor condom.
cruiser54 is offline
post #5 of 5 Old 03-11-2010, 06:09 AM
dagr8tim
dagr8tim's Avatar
1997 XJ Cherokee
I know the old 4 cylinder ford tempo/mercury topaz's (88 - 94) came with a rubber boot for the dist.
Now that you mention it, I may try to troll the yards next time I'm there for one. I'm pretty positive it would be a direct fit with no trimming.
EDIT:
I went digging through my files and found some images. It also looks like the 3.0 Vulcan V6's also had them. I'd be willing to bet you could find them on the late 80's and early 90's Taurus/Sables also.
4 Cylinder 89 Topaz
V6 92 Topaz
Jeeping - The art of getting dirty & going broke while slowly heading nowhere, and taking all day to do it.
97 XJ SE - The War Wagon
98 TJ - Mall Crawler/Light Trail Rig
dagr8tim is offline
cherokee , distributor , protection
Oil In Distributor.... Jmprep XJ Cherokee Technical Forum 5 05-01-2009 03:27 PM
Wheel bearing protector shouston75 XJ Cherokee Technical Forum 5 09-15-2008 02:19 PM
Source for door protector strips? Rallred XJ Cherokee Technical Forum 1 05-15-2008 06:00 PM
Repair procedure for door protector trim QwkTrip XJ Cherokee Technical Forum 5 11-16-2006 05:57 PM
Made my own rear bumper sill protector Fred85 XJ Cherokee Technical Forum 3 10-09-2005 12:57 PM
