Dissapointed with Quadratec Leafsprings - Page 2 - JeepForum.com
post #16 of 21 Old 11-19-2012, 06:10 AM
Millermagic
I had the Crown HD springs - they rode great and flexed great ... settled to stock ride height very shortly.
2000 XJ - 3.5'' Lift & Skinny Mudders.
Previous: A CJ, Few TJs and JK.
Millermagic is offline
post #17 of 21 Old 11-20-2012, 10:00 AM
dickdale69
Am looking at replacing the leaf springs just wondering if anyone has heard of General Springs? are they a good spring for the price or a POS. http://www.generalspringkc.com/product_p/97-539.htm
TIA
dickdale69 is offline
post #18 of 21 Old 11-20-2012, 01:26 PM
sAe23
1995 XJ Cherokee
TIA
Don't know about their quality, but, someone here has used one of their charts in a post before.
And for comparison, Quadratec has an "OEM" standard rate spring W/O bushings for $75 so you might be saving a few bucks with the General brand.
But most springs start at over $100, so I'd wonder about quality...
sAe23 is offline
post #19 of 21 Old 11-20-2012, 05:51 PM
LEO_WRANGLER
Reading this thread with great interest. I'm coming up on replacing my XJ's shocks, got a busted shackle on the left rear, plus the usual general sagging.
I was looking at those Standard Duty leafs on Quadratech. This thread has convinced me it might be better to get the HD leafs, or maybe the Dormans from Advance Auto. My Jeep is pretty much bone stock, and stays pretty much on pavement, but I want to get that sagging issue fixed.
I've swapped engines, but never leaf springs. How hard is the job? Are there any writeups here on the process?
Oh, and Shout out to kateean2 -- you're in my old home stomping grounds. Went to school down there at TSTI.
Thanks,
James
LEO_WRANGLER is offline
post #20 of 21 Old 11-21-2012, 06:03 AM
JTM1
1988 XJ Cherokee
XJ Drive, Call Quadratech and see what they tell you first, if they don't resolve your issue you can run longer shackles or lift blocks. How old are your shocks? If they are shot, it will cause your leaves to wear prematurely; my jeep leans to one corner because I destroyed a rear shock on a week long overland trip. Also, the shackle thing is a myth now.
Justin
88 XJ-Lifted, Locked, and on Jackstands
69 CJ5-In peices
JTM1 is offline
post #21 of 21 Old 11-21-2012, 07:33 PM
ROTTEN
Leo_wrangler
PB blast the shackle bolts for a week or 2
Jack it up pull wheel
Have an extra jack handy
Cut off both u bolts. Usually the nuts won't break free
Use impact to hopefully zip out the shackle end bolts.
Use impact on fixed eye
Now if you have a hitch you might have trouble if the bolts won't come out. Just use a big punch or torch or something to get that bolt out. Cut the spring end in half in the center.
Once you get the assembly out put the new one in. You gotta use some force to get the bushings in. Use the other jack to raise and lower your axle to align the pack
New ubolts and button it up.
This is based on my experience. All my bolts came out easily. My shackles were frozen in place so that made it a little challenging
I'm new
ROTTEN is offline
