Disc brake rotor temps - JeepForum.com
post #1 of 7 Old 09-09-2013, 06:59 PM Thread Starter
jstaples
My front disc brakes on my 1996 Jeep Cherokee overheated (non-ABS, front disc, rear drum) to the point where smoke was coming from the right front wheel well. I changed the calipers, master cylinder, and proportioning valve. Also planned to change the brake hoses but couldn't get the flare nuts loose, even with a flare nut wrench and PB Blaster. After a test drive, I measured the temp of the front rotors with an IR thermometer. Both were about 190F. Seems a little high to me. Anyone know what would be considered a normal temp? I plan to put on new rotors and pads but I'm afraid I'll damage $250 Hawk rotors and pads.
jstaples is offline
post #2 of 7 Old 09-09-2013, 09:07 PM
wgirvine
1992 XJ Cherokee
Only two reasons for disc brakes to overheat like that...
(1) You were driving with your foot on the brake pedal, or
(2) The brakes hoses have swelled up on the inside. They will look normal on the outside, but the inside will be swelled shut. They act like a one-way check valve. You can force the fluid to the brakes with your foot, but when you release, the pressure keeps the pads clamped to the rotor.
Change the hoses.
The road goes on forever, the party never ends....
wgirvine is offline
post #3 of 7 Old 09-10-2013, 04:57 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
I think we need to verify that 190* is too high. I doubt it is as I've done brake testing with an IR gun and saw temps after application of brakes up in the 500+* temps.
If you own a Renix Jeep, you must check this out:
My Jeep technical photos:
cruiser54 is offline
post #4 of 7 Old 09-10-2013, 05:30 AM
Newtons3
Newtons3's Avatar
Those temperatures sound reasonable to me depending, of course, on the pad material you are running.
Newtons3 is offline
post #5 of 7 Old 09-10-2013, 08:22 AM
wgirvine
1992 XJ Cherokee
He said it was smoking. That is too hot.
wgirvine is offline
post #6 of 7 Old 09-10-2013, 10:04 AM Thread Starter
jstaples
The brakes were smoking before I did the repairs. I did not measure the temps at that time but I could barely could hold my hand near them. I'm assuming the caliper was stuck. But I changed the master cylinder and proportioning valve as well. I planned on changing the brake hoses but couldn't get the flare nuts to budge. In fact, the flare nut wrench was starting to round off the nuts. I'm afraid if I do enough damage, I'll need to change the hard lines as well. I'm willing to do that repair at some point but not a good time right now.
jstaples is offline
post #7 of 7 Old 09-10-2013, 11:17 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Use a propane torch to heat up the nut. Spray on penetrating oil while still hot. You may need 2 vice-grip wrenches to break it loose.
CJ7-Tim is offline
