Differential oil - JeepForum.com
post #1 of 4 Old 06-07-2005, 12:27 PM Thread Starter
Rescue XJ
Differential oil
Hey guys Im redoing my rear diff seal, and changing the fluid to synthetic. How much oil do I need for each axle?
White 96 XJ Sport
Jeepforum Minister of Sarcasim
4L HO Command track Dana 30 front Chrysler 8.25 rear CarQuest XD shocks, Federal Signal emergency stuff, MCX 1000 DES-XL, TK-940, Astro Spectra W3 encrypted, Magnaflow 18" body, Medical supplies, MREs, Gatoraid, Shovel, MagLite, body armor, grappling hook, annoying squeeking sound from my door, otherwise stock for now.
White Jeep Club Member #911
Code 3 Jeep Club Member #1
Eagle Scout Jeep Club Member #2
Originally Posted by tx50cj3a
Vatozone.
Originally Posted by 92 Briarwood
I think "that look" is what they teach the chicks in 6th grade when they show them "that film" behind closed doors.
Rescue XJ is offline
post #2 of 4 Old 06-07-2005, 12:41 PM
Lagooz00XJ
4 quarts was more than enough for both of my axles.
2000 XJ 4.0 aw4 np 242
Bastard 2.5" Lift
30" Kumho MT's
Belly Armor
RE H&T w/ front shaft
Lagooz00XJ is offline
post #3 of 4 Old 06-07-2005, 12:53 PM
kg6mti
1987 YJ Wrangler
4 quarts sounds about right. For diffs like a Dana 30 or 35 you will want to make certain that you fill them until the oil runs out of the plug hole.
Good Luck!
Experience is what you get when you get what you didnít want.
kg6mti is offline
post #4 of 4 Old 06-07-2005, 06:23 PM
lbsnowryder
One notch above Redneck!!
lbsnowryder's Avatar
If i remember correctly on my 88 Dana35 i used 1 and 1/4 quarts to fill each diff. So a total of 3 quarts and you should have around 1/2 a quart left. You should just fill until it seeps out the fill hole but i think that is around what i used.
LB
_____________________________________
I own a Jeep, it's red and has big tires
lbsnowryder is offline
Differential Oil Ryan949 XJ Cherokee Technical Forum 3 08-21-2007 10:11 PM
Differential. NjXj XJ Cherokee Technical Forum 2 06-05-2007 03:03 PM
differential ID artboy XJ Cherokee Technical Forum 4 05-11-2007 07:08 PM
Differential - RTV 95Cherokee- XJ Cherokee Technical Forum 5 04-21-2006 04:05 AM
Differential JBACA XJ Cherokee Technical Forum 4 04-01-2006 06:18 PM
