differential ID - JeepForum.com
post #1 of 5 Old 05-11-2007, 06:20 PM Thread Starter
artboy
artboy's Avatar
front differential
I am trying to find out if I have an open or LSD front end by jacking my XJ in neutral and spinning the wheels. Here is what happens ... when I spin a wheel (either side) the other one does nothing (the driveshaft turns though).
I thought with an open diff they spin opposite and a LSD they spin in the same direction. my wheels seem disconnected from each other ...is that normal?.
1993 XJ Sport RIP (Parts) - 189k, white, 4.0, automatic, command-trac NP231
1996 XJ Sport Daily Driver - 190k, stone white, 4.0, automatic, selec-trac NP242.
2005 Wrangler Rubicon Summer Toy - 26k, 100% STOCK...silver, automatic, soft and hard tops and doors
"life moves pretty fast... if you don't stop and look around once and awhile, you could miss it"...F. Bueller
artboy is offline
post #2 of 5 Old 05-11-2007, 06:46 PM
madrabbitt
madrabbitt's Avatar
um.
front=open from the factory.
shift it into 4 wheel drive, THEN jack it up and try to spin the tires, see what happens.
Installing HID's in stock housings is bad.
"When you see someone who needs help, help them. When you see someone who needs a hug, hug them... Help those who can't help themselves." -Sgt Andrew Tingwall, NMSP. End of watch 6-10-2009
madrabbitt is offline
post #3 of 5 Old 05-11-2007, 06:59 PM Thread Starter
artboy
artboy's Avatar
Yup... now they spin opposite. I don't quite understand why having it in 4wd makes a difference... all that does is engage the transfer case....it has noting to do with the axle (I don't have vacuum axle disconnect). would like to know why
artboy is offline
post #4 of 5 Old 05-11-2007, 07:02 PM
madrabbitt
madrabbitt's Avatar
well, your selec-trac equipped xj wouldnt have a vac disconnect anyway, even if it were 92 or older.
and you did that quick.
post #5 of 5 Old 05-11-2007, 07:08 PM Thread Starter
artboy
artboy's Avatar
Thanks MadRAbbitt..... she was already up on stands in the garage... ran out and just shifted it. I still don't understand why that made a difference... ?????? Does the diff need resistance via the TC to engage the wheels to spin opposite?
artboy is offline
Differential Oil Ryan949 XJ Cherokee Technical Forum 3 08-21-2007 10:11 PM
Differential. NjXj XJ Cherokee Technical Forum 2 06-05-2007 03:03 PM
Differential - RTV 95Cherokee- XJ Cherokee Technical Forum 5 04-21-2006 04:05 AM
Differential JBACA XJ Cherokee Technical Forum 4 04-01-2006 06:18 PM
Differential oil Rescue XJ XJ Cherokee Technical Forum 3 06-07-2005 06:23 PM
