Differentail Housing has oil leak - do I have a problem? - JeepForum.com
post #1 of 19 Old 07-16-2010, 11:14 PM Thread Starter
akajean
1997 XJ Cherokee
My '97 cherokee sport's differetial seems to have some oil covering the lower part, I think it's supposed to be dry... and also the muffler is making sounds....
scared, is it still ok to drive?
akajean is offline
post #2 of 19 Old 07-16-2010, 11:40 PM
freakinheep89
which differential and do you mean that just the differential housing is covered in fluid(the outside of the axle) or when you take the diff cover off the differential itself is almost dry?
TJ-
95 ZJ 5.2- D30/XJ shafts/D35 Yukon alloys,249, 2"BB, 30x9.5"Wildcat EXT,lots of motor mods, rancho shocks & stabilizer.
Originally Posted by slayercr23 View Post
How would i go about Stroking it?
freakinheep89 is offline
post #3 of 19 Old 07-16-2010, 11:44 PM Thread Starter
akajean
1997 XJ Cherokee
Thanks for the reply
it's the rare one and the cover (the round part) is covered in fluid, I haven't opened the cover
akajean is offline
post #4 of 19 Old 07-17-2010, 01:08 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Even a slight amount of oil leakage spreads out and appears to more than it what it actually is. As long as you keep the differentials full to the bottom of the fill/inspection hole on the cover, it will be fine.
The muffler can make noise if it is loose or if it has a leak, both issues can be fixed rather easily.
CJ7-Tim is offline
post #5 of 19 Old 07-17-2010, 01:12 AM Thread Starter
akajean
1997 XJ Cherokee
The muffler can make noise if it is loose of if it has a leak, both issues can be fixed rather easily.
Tim, thanks so much for the reply. I think I'll still drive it during the weekend and take it to a mechanic on Monday.
Can the problems in muffler and differential result a drop fo mpg? My mpg is like 6-8....really poor...and that's why I checked the bottom of the car. The parts under the hood seemed to be ok, tho.
akajean is offline
post #6 of 19 Old 07-17-2010, 01:25 AM
CJ7-Tim
CJ7-Tim's Avatar
Originally Posted by akajean View Post
....a drop of mpg? My mpg is like 6-8....really poor...
No, neither of those will cause an MPG drop.
You should get 12-15 mpg in the city and 18-22 on the highway. If all your tune-up parts are fresh, you have another problem, possibly with the O2 sensors, a clogged Catalytic Converter, or the Coolant Temperature Sensor. The only way to find the problem is to test the systems or sensors that are possible causes of the mileage drop. You want to be sure what is wrong before you spend any money on new parts. Simply throwing new parts at a problem is stupid if you don't know what is wrong with it.
CJ7-Tim is offline
post #7 of 19 Old 07-17-2010, 01:31 AM Thread Starter
akajean
1997 XJ Cherokee
I just got the fornt o2 sensor changed because the CEL was on and I got the code for the front o2 sensor. Now the light is off but the mpg did not rise. Air filter is clean, radiator is new, fans are running ok, but my friend who knows better about cars found the hood too hot and suggested maybe I should get a radiator flush..
Thanks for the advice I'll keep in mind.
akajean is offline
post #8 of 19 Old 07-17-2010, 07:42 PM
freakinheep89
anybody know if the XJ's have the adaptive memory controls that have to be reset like the ZJ's? if so that may be the problem
TJ-
post #9 of 19 Old 07-17-2010, 07:49 PM Thread Starter
akajean
1997 XJ Cherokee
do you mean that after the CEL is off, they alse have to reset the computer memory, otherwise the mpg's gotta be the same as before the 02 sensor was replaced?
akajean is offline
post #10 of 19 Old 07-17-2010, 07:54 PM
freakinheep89
yes on ZJs there are adaptive memory controls that must be reset after a major component change like an o2 sensor, i changed mine yesterday and had to clear em out. it makes alot of difference. just disconnect your positive cable and touch it to the block or alternator or whatevers close to it on the 4.0, hold it there for 30 sec, then completely disconnect the battery for 30min.
TJ-
post #11 of 19 Old 07-17-2010, 07:59 PM Thread Starter
akajean
1997 XJ Cherokee
Thanks a lot for the suggestion. Just one concern, will this remove all memory so I will not be able to discover other potential problems that I wasn't aware of before? (i hope this makes sense...
akajean is offline
post #12 of 19 Old 07-17-2010, 08:13 PM
cornbrizzle
1992 XJ Cherokee
Your xj learn's all the time it adapts to your driving style . If you clear your memory it take about 50 key starts to adapt totaly , when you replace a sensor it adapts from that point .
Brizzle
“Don’t Tread On Me”
www.highsprings.com
cornbrizzle is offline
post #13 of 19 Old 07-18-2010, 10:52 AM Thread Starter
akajean
1997 XJ Cherokee
Brizzle
thanks Brizzle, do you mean I don't have to reset it because it's already started to learn from a new point after the o2 sensor was replaced?
akajean is offline
post #14 of 19 Old 07-18-2010, 12:04 PM
freakinheep89
it will learn over again, it just takes alot longer than if you reset the adaptives. resetting the adaptives will not prevent you from discovering future probs since any codes present will pop up again since you did not replace them, i would go ahead and reset it
TJ-
post #15 of 19 Old 07-18-2010, 01:04 PM
cornbrizzle
1992 XJ Cherokee
Correct
Brizzle
“Don’t Tread On Me”
www.highsprings.com
diff leak , differential leak , fluid leak , fluid level
oil filter housing leak budgetHERO XJ Cherokee Technical Forum 2 03-28-2009 08:33 PM
oil filter housing leak ilovjeep XJ Cherokee Technical Forum 5 09-29-2008 11:54 PM
oil filter housing leak Ozzman2079 XJ Cherokee Technical Forum 11 11-07-2004 07:41 PM
darn oil filter housing leak Ozzman2079 XJ Cherokee Technical Forum 4 01-29-2004 08:09 PM
Oil filter housing leak oldford XJ Cherokee Technical Forum 1 12-21-2001 07:15 PM
