Different question... - JeepForum.com
post #1 of 18 Old 03-21-2013, 10:52 PM Thread Starter
cbrant
So my brother rolled his '98 Classic and the roof is pretty muffed up. Dented, creased, and wavy. We jacked it up from the interior, but that only fixed it a little. So, my question is, has anyone got a better way to fix this? We were considering somehow finding a donor cherokee and chopping the roof then splicing. That seems like a lot of work to me, so I figured I'd see what the true Dr. Frankensteins have for ideas. Thanks!
cbrant is offline
post #2 of 18 Old 03-21-2013, 10:59 PM
cory4um
Find a blown, wrecked, or missing drive train xj and swap what needs to be swaped (engine, body panels, drive train)
cory4um is offline
post #3 of 18 Old 03-22-2013, 01:13 AM
DoctorTim
^ easiest and best route to take.
96 XJ, geared, 8.8, 5", 33s, dash
DoctorTim is offline
post #4 of 18 Old 03-22-2013, 12:27 PM
Motorcharge
Cut the top off and cage it.
|SOLD|
| June 2015 COTM |
Motorcharge is offline
post #5 of 18 Old 03-22-2013, 12:31 PM
Hudson
Always thinking one step ahead.
OP don't even bother to try to "splice it". It'd be much easier to do this;
Live To Die. You're Not Going To Get Out Of This One Alive.
Build Thread - http://www.ausjeepoffroad.com/forum/showthread.php?t=121903
Hudson is offline
post #6 of 18 Old 03-22-2013, 01:40 PM Thread Starter
cbrant
For some reason that seems like more work to me, but I have a difficult time arguing it. I suppose it depends on how bad the other Cherokee really is.
cbrant is offline
post #7 of 18 Old 03-22-2013, 01:59 PM
sAe23
1995 XJ Cherokee
If you ask real nice like, maybe a collision repair shop would offer suggestions...
sAe23 is offline
post #8 of 18 Old 03-30-2013, 12:03 AM Thread Starter
cbrant
So, I think we are still going with the roof splice option. My next question is about what years will work. I know 98-01 is the identical body style. (It's a 4 door) but looking at earlier models roofs they look very similar. Does anyone know or can confirm if other years would be a match. Pillars included.
cbrant is offline
post #9 of 18 Old 03-30-2013, 12:28 AM
sAe23
1995 XJ Cherokee
Ooh ooh, you should splice in a Land Rover Defender roof! Get those nifty little side windows
sAe23 is offline
post #10 of 18 Old 03-30-2013, 12:45 AM Thread Starter
cbrant
Those are probably a little harder to come by than one would think... Hahaha good idea tho!
cbrant is offline
post #11 of 18 Old 03-30-2013, 01:14 AM
Timo_90xj
Timo_90xj's Avatar
Sooo.. chopping off the old roof from the donor XJ (including removing all the necessary body panels, finding and drilling all the spot welds, etc..), then finding the same spot welds on the rolled XJ and drilling them open, then welding in the new roof (hoping it wasn't bent during the process of chopping it off and transporting it) and actually make the structural integrity good and making sure your brother's XJ won't end up being all bent and out of shape is easy? Yeah, good luck with that
Finding a donor XJ from similar era, and swapping over parts that are in better shape takes a lot less work. If you're really into doing bodywork, get the XJ rpoughly bent back to shape, chop off the roof, build a cage and make it a trail XJ. Trying to properly splice in a roof section on a unibody vehicle when unwrecked vehicles are found fairly cheeply is just stupid IMO, and it's even more stupid to trying it and doing it all wrong
***Under construction***
Timo_90xj is online now
post #12 of 18 Old 03-30-2013, 05:54 AM
Pats94
Skin a donor roof in at the drip rails. Isn't that tough.
If its stock it sucks and if it scares the hell outta ya its just about right!
Pats94 is offline
post #13 of 18 Old 03-30-2013, 10:26 AM
habbyguy
Photos would help, but I do agree that if it's very damaged at all, a new donor car would be the most logical option. Trying to get a new slice-n-weld top lined up well sounds like a nightmare to me.
I once helped "fix" an 80's Land Cruiser that had rolled. The owner wasn't worried about aesthetics, so all we had to do is get the windshield "hole" "windshield-shaped". We were using big honkin' hydraulic rams and creating some serious violence to get it back to reasonably straight (a very, very relative term). When we were done, it still looked like it had been rolled, but the windshield was in and didn't even leak (or break, at least not during the few years since the fix). The driver's door doesn't fit perfectly, and the roof still has a "custom shape" but it's still on the road.
habbyguy is offline
post #14 of 18 Old 03-30-2013, 01:45 PM
Timo_90xj
Timo_90xj's Avatar
That would help what? OP wrote the pillars are also crushed/ dented, and pulling the pillars straight won't make them strong since they've been already crushed, they need to be replaced.
As I said, IMO it's a stupid idea to replace the roof in the first place, and it's even more stupid doing it all wrong. Chopping & caging the XJ would be the way to go.
post #15 of 18 Old 03-30-2013, 01:54 PM
Motorcharge
Caging it or swapping the good parts to a solid unibody is the only way to do it without a ton of extra work and money. Even cutting from the pillars up off another XJ and welding it in isn't going to be as strong as the original.
Cage it or swap everything. No sense in ruining two XJs.
|SOLD|
| June 2015 COTM |
