difference between 96 and 04 4.0 cam? - JeepForum.com
post #1 of 6 Old 07-25-2010, 05:05 PM Thread Starter
jeepman4723
Hey, Im replacing my 96 4.0 with an 04 4.0 and I know I gotta use all the old intake and external stuff, but is the cam different enough to have to swap it too? through oreily there are 2 diff part numbers, but all the cam specs are pretty identical? Thanks, zack
jeepman4723 is offline
post #2 of 6 Old 07-25-2010, 05:17 PM
Mickey_D
2004? I hope that was a typo and you're either looking at a 94 or an 01 because I think the 3.7L V-6 replaced the 4.0 I-6 across the Jeep board.
To answer your question, if it is a 94 or 01, doesn't matter. Anything from 91 up to 01 is pretty much the identical block.
1997 ZJ 5.2 Orvis, Baby!
1953 Willys M100 trailer Tagalong
________________
[_][][][][][][][][_]
#4
Mickey_D is offline
post #3 of 6 Old 07-25-2010, 06:21 PM
billabongopblue
although i dont no the answer, the grand and the wrangler both used the 4.0 in 04
96 Classic - 3" Lift - 31" BFG AT's - 29 spline 8.25 - 4.10's - Tow Hooks - RE track bar - RC Dif Guard - Cowl Intake - LeBaron Vents - Dynomax Catback - IRO H&T
billabongopblue is offline
post #4 of 6 Old 07-25-2010, 08:56 PM
Mickey_D
Good Lord I can't believe I forgot about that.
I was thinking of the Liberty and my boss's '10 Wrangler.
________________
#4
Mickey_D is offline
post #5 of 6 Old 07-25-2010, 09:46 PM
scupking
2006 was the last year of the 4.0.
scupking is offline
post #6 of 6 Old 07-25-2010, 09:49 PM
90si
check out jeepstrokers.com for cam profile info
90si is offline
4.0 , cam , camshaft , engine swap
99-01 Hub difference sublime600 XJ Cherokee Technical Forum 1 10-28-2008 06:00 PM
How to tell the difference? homelessduck XJ Cherokee Technical Forum 3 04-09-2006 11:23 PM
The Difference StokedXJ11 XJ Cherokee Technical Forum 1 03-08-2006 07:46 PM
How big of difference is there with a K&N JeepZJlover XJ Cherokee Technical Forum 3 12-28-2005 12:15 AM
11.5 and 10.5? How much difference is there? wrecked XJ Cherokee Technical Forum 4 10-25-2004 09:08 PM
