diff fluid and transfer case fluid - JeepForum.com
post #1 of 15 Old 02-09-2011, 11:01 AM Thread Starter
scottxj96
Just wondering whats the best brand, type, etc
I'm wondering the difference between atf 3 and 4 and what ever else is out there haha
Thank you in advance!
scottxj96 is offline
post #2 of 15 Old 02-09-2011, 11:58 AM
jeepkid03
Winning
jeepkid03's Avatar
For the Transfer Case: Dex III or ATF+4 is fine. ATF+4 is synthetic
For the Diffs: 75w90 for normal use, 75w140 if you tow frequently. Any brand will be fine, and I've had good luck so far with Mobil 1 synthetic gear oil or Coastal gear oil. The more important thing is that if you have a limited slip differential, you must add the additive in with the fluid.
-Josh
My 0331 Head Swap How-To Thread:
Build Thread:
jeepkid03 is offline
post #3 of 15 Old 02-09-2011, 12:07 PM
fourlow
1994 XJ Cherokee
http://www.allpar.com/mopar/transmissions/fluids.html
Current setup:
94 Xj 110,000 miles
Rustys Air Tube
JeepersandCreepers Bored out TB
GDI 3 core radiator
Flowkooler Water Pump
Suspension:
RE 3.5" (actual about 4 inches) 6030 SUPER-FLEX, RE1600 Adjustable Track Bar
Wheels/Tires:
Rock Crawler 152 Series, 3.75 Backspacing
31inch BFG MT's
fourlow is offline
post #4 of 15 Old 02-09-2011, 12:29 PM Thread Starter
scottxj96
what is the additive?
post #5 of 15 Old 02-09-2011, 12:31 PM
Paradise XJ
1988 MJ Comanche
Friction Modifier
LSD Modifier
1990 XJ Laredo - White & Chrome
1988 MJ Pioneer - Metallic Green and Black
Paradise XJ is offline
post #6 of 15 Old 02-09-2011, 01:12 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
From the JEEP Factory Service Manual
Cherokee Fluid Capacities
Engine Oil
-2.5L (4cyl) - 4.0 Quarts (3.8L)
-4.0L (6cyl) - 6.0 Quarts (5.7L)
Cooling System
-2.5L (4cyl) - 9.0 Quarts (8.5L)
-4.0L (6cyl) - 10.5 Quarts (9.9L)
Automatic Transmission
-4.0L (6cyl) The AW-4 Automatic Transmission uses Transmission Fluid labeled Dexron-III/Mercon.
- Drain and Re-fill = 4 Quarts (3.8L)
- Filter and complete fluid exchange = 8 Quarts (7.8 L)
-2.5L (4cyl) Chrysler/Mopar Automatic Transmissions use ATF+3 or ATF+4 Type 7176
Manual Transmission
-AX-5 5 speed manual - 3.3 quarts 75W-90 GL3 or GL4 (NOT GL5 or GL5 compatible as incorrectly stated in some Owners Manuals)
-AX-15 5 speed manual - 3.32 quarts 75W-90 GL3 or GL4 (NOT GL5 or GL5 compatible as incorrectly stated in some Owners Manuals)
-NV3550 5 speed manual - 2.1 quarts Mopar fluid part # 04874464AA or Snychromax (meets Mopar MS-9224 specs)
The NLGI specs are important - typical NLGI GL-5 gear oil carries added sulphur used as an Extreme Pressure (EP) lubricant. Especially when heated, sulphur is antagonistic to yellow (copper-based) metals - and the synchronizer rings and any bushings in the AX-15 are bronze. Most synthetic gear oils are rated GL-5 and are listed as "safe for use with yellow metals."
Unlike API specs (to API Service SL/CJ-4,) NLGI Service specifications are not reverse-compatible. Well-stocked parts houses will have both NLGI GL-3 and NLGI GL-5 mineral-based gear oil in stock all the time.
If you want to use a synthetic (RedLine, AmsOil, etc.) either check the back of the bottle or check the manufacturer's website to make sure it's safe for use with yellow metal - using sulphur-bearing gear oils usually results in draining your synchronizer rings at your next fluid change...
Transfer Case
-NV231 Part-Time (Command-Trac) - 2.2 Pints (1.0L) Dexron III/Mercon
-NV242 Full-Time (Selec-Trac) – 2.85 Pints (1.3L) Dexron III/Mercon
Front Axle
-Dana 30 - 2.5 Pts (1.2L) SAE 75W-90
Rear Axle
-When equipped, Trac-Lok Limited Slip rear axles require 4 ounces of Friction Modifier Additive
-Dana 35 - 3.5 Pints (1.66L) SAE 75W-90
-Dana 44 - 4.0 Pints (1.89L) SAE 75W-90
-Chrysler 8.25 - 4.4 Pints (2.0L) SAE 75W-90
For towing and off-road use SAE 75-140 synthetic
CJ7-Tim is offline
post #7 of 15 Old 02-09-2011, 01:19 PM
LandRover
LandRover's Avatar
^^ Great post, thanks.
Related question... I'm about to install a powertrax locker in my 8.25 rear, and I saw the capacity as 2.0L in the manual... well gear oil comes in Quarts... it's something like .94 Liters per quart, so really close. I was going to buy another bottle, but I figured that the stuff that sticks to the walls, etc, will make up for the difference...plus, I'm figuring that the locker will take up a little more room than the spider gears that it's replacing... ? How close is the 2.0L capacity listed in the manual? Is that pretty accurate for the 8.25?
RHD '98 XJ
RE 3.5", Bushwaker Flat Flares,
OR-Fab bumpers, PowerTrax locker,
Sliders, Goodyear Duratrac 33's
LandRover is offline
post #8 of 15 Old 02-09-2011, 01:27 PM
MONSooNmonkey
What your user manual says.
This thread will be 13098234 years old and still no definitive answer will be had.
Sadface :(
MONSooNmonkey is offline
post #9 of 15 Old 02-09-2011, 01:31 PM
CJ7-Tim
CJ7-Tim's Avatar
Service the front diff. Buy enough fluid for both.
CJ7-Tim is offline
post #10 of 15 Old 02-09-2011, 04:04 PM Thread Starter
scottxj96
wow thats perfect. thanks alot!
post #11 of 15 Old 02-09-2011, 04:07 PM
LandRover
LandRover's Avatar
No.
RHD '98 XJ
post #12 of 15 Old 02-09-2011, 04:15 PM
B2CARPEN
Why would you want to leave that gunk **** all inside the diff??
One would think that it would be wise to clean it out entirely while you have everything open and apart, but hey it's your jeep. With that mindset, you should save yourself the money and time and just pour that filthy (never changed) used diff fluid back into your diff then just add water if it's a little low
Founder of
B2CARPEN is offline
post #13 of 15 Old 02-09-2011, 05:15 PM Thread Starter
scottxj96
hahahahahahh
post #14 of 15 Old 02-10-2011, 09:05 AM
LandRover
LandRover's Avatar
Great idea, thanks!
It's never been changed because I've only owned the Jeep for a couple of months...
But let's recap:
Me: "Is the 2.0L measurement pretty accurate?"
Response 1: "do another thing too"
Response 2: "You are dumb because I'm assuming you would do something that only a moron would do."
This is beautiful. Maybe I'll go ask over at Pirate 4x4....
My apologies for providing too much info in the original question. I'll rephrase:
Book say 2L. Book right?
RHD '98 XJ
post #15 of 15 Old 05-03-2013, 03:38 PM
DZINE
1997 XJ Cherokee
Great idea, thanks!
But let's recap:
you have been provided with the answer multiple times in this thread. you dont have to rephrase as if we are all morons that dont understanding your question.
If you are putting a locker in the rear end. 1.remove current diff,
2.while you have the housing open and nothing inside give it a good clean. you want to wipe all that SLUDGE out off your diff housing. OIL SLUDGE = BAD. with the housing completely clean it will take 2.0L. BUT while changing the oil in rear diff you may as well do the front too.
DZINE is offline
Diff fluid/transfer case fluid scoobyguy07 XJ Cherokee Technical Forum 2 01-08-2011 11:07 AM
Which fluid should be used in transfer case? car5car XJ Cherokee Technical Forum 3 12-06-2008 10:53 PM
Automatic Transmission fluid change, and Transfer Case fluid change questions. MageXX9 XJ Cherokee Technical Forum 4 04-28-2007 05:08 PM
Diff and Transfer case fluid change ???'s TheEddie XJ Cherokee Technical Forum 3 03-26-2007 04:40 PM
Diff and Transfer Case Fluid Change?? Osteonis XJ Cherokee Technical Forum 17 10-08-2004 10:38 AM
