Diesel Engine Swap - Page 2 - JeepForum.com
post #16 of 20 Old 09-21-2010, 11:20 AM
devildog6133
so phil, whould you think a 4bt cummins would be too heavy? i have a 6.5 in skyjacker suspension lift on my wj with 35 bfg's how easy is it to tune them and can i take my hyper tech chip out of my 4.0 and put it in the 4bt?
devildog6133 is offline
post #17 of 20 Old 09-21-2010, 11:32 AM
Fooly
Yes, more information on the 4bt swap please.
EDIT: Actually, after some searching, I'm not sure I would put something that heavy into a unibody, and you would have to fabricate a lot to fit in the NV4500, maybe a lighter turbo-diesel though?
WANTED: XJ/WJ/ZJ IN SC/NC.
Fooly is offline
post #18 of 20 Old 09-21-2010, 11:59 AM
BigBass
Thats why I said a 6.5 its not as tunable but still would give you good power to weight and its lighter.
All Long Islanders Check out OutLawedOffroad.com throw my user name BigBass in the referral box
BigBass is offline
post #19 of 20 Old 09-21-2010, 01:16 PM
Timo_90xj
Timo_90xj's Avatar
Naaahh, skip the heavy pigs like V8 GM diesels or Cummins 4bt, and put in an old Merc diesel (OM603/606, or even a 617). XJ is light vehicle, so you can easily use passenger car engines. The old merc diesels are all pretty durable and tunable engines. Stock turbo internals of a 603 or 606 should handle up to about 300hp. Stock engines aren't that powerful, but rather spectacular when built right
Don't know about their street-legality in the USA though.
YouTube - world's fastest diesel mercedes w123 300d
This one is with a slightly newer merc diesel IIRC:
YouTube - Mercedes W124 300TD Diesel 500+HP
YouTube - MB 300 turbodiesel
***Under construction***
Timo_90xj is offline
post #20 of 20 Old 09-21-2010, 02:07 PM
Phil12
1990 XJ Cherokee
[QUOTE=Timo_90xj;10161573]Naaahh, skip the heavy pigs like V8 GM diesels or Cummins 4bt, and put in an old Merc diesel (OM603/606, or even a 617). XJ is light vehicle, so you can easily use passenger car engines. The old merc diesels are all pretty durable and tunable engines. Stock turbo internals of a 603 or 606 should handle up to about 300hp. Stock engines aren't that powerful, but rather spectacular when built right
As I said in my previous comment, my other car is an 83 Mercedes with the 5 cylinder turbo diesel. It's not a light engine but I don't know how close it is to the Jeep engine in weight. If you want to look into tuning one check on PeachParts - Mercedes Parts & Tech Info
The first car in your videos has an amazing engine in it. I will look around, I have seen pic. of the engine and the build up of the car.
Phil12 is offline
4bt , crd , diesel , engine , swap
XJ diesel engine swap evertheinsmit XJ Cherokee Technical Forum 5 03-04-2012 05:42 AM
engine swap (with a diesel one) Mina XJ Cherokee Technical Forum 18 02-11-2009 03:17 PM
diesel swap kit medicbear XJ Cherokee Technical Forum 21 03-14-2008 11:09 AM
diesel engine swap? jeepjack1995 XJ Cherokee Technical Forum 14 01-03-2008 04:01 PM
