diesel - JeepForum.com
post #1 of 8 Old 04-21-2006, 07:14 PM Thread Starter
fourhwheelin
diesel
eneyone have eney info on I4 or I6 diesel turbo swaps has it been done or am i the first. if it has been done does eneyone have pic's or what i should look for in do this conversion? i was planing on converting that into vegtible oil. O and i will be going in an 88 cherokee for those that dont know your in the cherokee forum...lol
fourhwheelin is offline
post #2 of 8 Old 04-21-2006, 10:05 PM
twisted_ed
twisted_ed's Avatar
search for it, theres alot of info on diesel swaps. I woulc google this too cause there are some webpages on cherokees with diesel swaps
1990 Jeep Cherokee Laredo
4.0L
Automatic Tranny
NP242 Transfer case
Dana 30 front, 35 custom rear differentials
Mods:
RE 4.5" Lift
32x11.50 BFGoodRich M/T KM's
American Eagle 058 Polished Aluminum Wheels, 3.63" BS.
Grand Cherokee Rear Disc Brake setup
Custom Downpipe W/ Cat Removed.
Dynomax Super Turbo Muffler.
Surco Roof Rack
twisted_ed is offline
post #3 of 8 Old 04-22-2006, 01:13 AM
weldmaster4000
is there any way to convert the stock 4.0 over to a diesel? havent researched AT ALL, just saw this post and respponded
91 cherokee, I6 4.0 bored .030 over (i dont know why)
bone stock
Originally Posted by grandman97
i was screamin at my friends to pee on my back but none of um would, so i had one pee in a gatorade bottle and then i poured in all over my back and legs
weldmaster4000 is offline
post #4 of 8 Old 04-22-2006, 03:21 AM
Timo_90xj
Timo_90xj's Avatar
There's propably a way to do it, but I'm pretty sure it wouldn't be easy. And it would definitely be very expensive, because there are so many parts you would need to change, and you would propably need to make some parts as well to make things fit etc..
***Under construction***
Timo_90xj is offline
post #5 of 8 Old 04-22-2006, 09:12 AM
xhavier_5478
1992 XJ Cherokee
you would be much better to just look for a donor diesel, and research the actual mechanics of a diesel motor.
1992 Jeep Cherokee Limited
Proud
xhavier_5478 is offline
post #6 of 8 Old 04-22-2006, 09:20 AM
Kuasimodem
Kuasimodem's Avatar
Maybe a GM 4.3L V6 diesel would be easiest. Use the stock trans for the diesel and an adapter from Advance Adapters to connect to your transfer case.
A late 80's S-10 Blazer would probably be a good donor to find, my neighbor has one.
White Jeep Club Member #1992
Original Rust Jeep Club Member #5!
Old Guy Jeep Club Member #1992
"The most terrifying words in the English language are: I'm from the government and I'm here to help." - Ronald Reagan
Kuasimodem is offline
post #7 of 8 Old 04-22-2006, 09:22 AM
asheets934
It would be so expensive and time consuming, if its possible, without a donor engine and tranny. Especially if you have the AW4 tranny, because of its electronics it doesnt really work with any engine except the 4.0. I read alot of the things out there on a diesel conversion for my XJ and gave up on the idea unless I come across a certain mercedes 5 cylinder diesel and transmission in a scrapyard . . .
asheets934 is offline
post #8 of 8 Old 04-22-2006, 09:33 AM
JoBo
The simple way to get a diesel cherokee would be to look for one that was brought in from Canada. They pop up every so often and most are on the west coast. They were available all over the world but here in the good old US and were built 100 miles from where I'm sitting in Toledo Ohio. It's the same engine used in the Liberty diesel. Later ones were electronically controled and the earlier ones were conventional. It's a VM diesel built in Italy. They had head gasket problems till the mid nintey's. Or you could look for a early 80's that had the Renualt turbo diesel. There's a guy on the net that used a Perkins diesel on some kind of car but diesels's are not for everyone but I would have one in a heartbeat
JoBo
Columbus, Ohio USA
2006 KJ CRD Atlantic Blue Pearl Coat Limited
2000 Cherokee Classic with factory 16" wheels
JoBo is offline
96 2.5 vm diesel injector Bjarni XJ Cherokee Technical Forum 3 12-15-2007 09:11 PM
98 XJ 2.5 td diesel cuts-out rhs@ivcoverings XJ Cherokee Technical Forum 13 02-11-2007 05:14 AM
Diesel anyone?? buddy2003 XJ Cherokee Technical Forum 25 03-24-2006 11:39 PM
Diesel XJ? Jeepin_XJ_101 XJ Cherokee Technical Forum 8 09-05-2005 11:01 AM
diesel xj fr8dog XJ Cherokee Technical Forum 13 01-19-2004 01:38 PM
