did tune up and a fuel injector now runs rough please help - JeepForum.com
post #1 of 4 Old 03-11-2012, 05:24 PM Thread Starter
Hunt3r
1991 XJ Cherokee
its a 89 xj i did a tune up and changed one fuel injector and the o rings on the rest now it runs really rough it does not wanto accelerate and when you do get it to highway speed you can feel the engine shake like a tire thats out of balance. thank you for any help
Hunt3r is offline
post #2 of 4 Old 03-11-2012, 05:25 PM
DoctorTim
make sure you plugged all of the connectors for the fuel injectors.
96 XJ, geared, 8.8, 5", 33s, dash
DoctorTim is offline
post #3 of 4 Old 03-11-2012, 05:27 PM
habbyguy
It would be really easy to get two of the injector plugs backward. You might try pulling the plugs off the injectors one at a time while the engine's running. If the idle doesn't get worse, you know that injector is part of the problem. If you pull off two plugs that don't make any difference, swap 'em and you're back on the road at 100%.
habbyguy is offline
post #4 of 4 Old 03-11-2012, 05:52 PM Thread Starter
Hunt3r
1991 XJ Cherokee
Thanks a lot it was two of the injector plugs switched around.
Hunt3r is offline
fuel injector , jeep , xj
New to Jeepin: Bought 89 Cherokee, it starts and runs but runs rough and stalls in D stockli XJ Cherokee Technical Forum 7 04-29-2013 08:48 PM
Tune up and replaced O2 sensor, now runs rough. NW99XJ XJ Cherokee Technical Forum 11 08-13-2011 06:55 PM
Jeep runs like crap and throws code 27 Fuel injector control circuit when cold Element96x XJ Cherokee Technical Forum 4 11-08-2009 07:00 AM
4.0 Runs Very rough after tune up???!!! Grobby1 XJ Cherokee Technical Forum 12 09-01-2009 03:55 PM
Fuel Injector Cleaner ---> solve Rough Idle??? 99Greenmachine XJ Cherokee Technical Forum 6 06-29-2009 07:36 PM
