Quantcast Detroit True Trac vs. Powertrax? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Detroit True Trac vs. Powertrax?
The Original 3/8" Ruffstuff Diff Cover!Ruffstuff Axle Simple Swap Kit!RUBICON EXPRESS Lift Kits and Accessories Available at Bas
Old 01-25-2007, 11:50 AM   #1
79bigmack
Cost aside, which is better, why?
Which one performs more smoothly with the D30/8.25 set-up?
Which one is quieter?
FYI- The intention is to have Limited Slips front and rear. And this will be a daily driver truck subject to North East US weather conditions (i.e. mainly ice/snow in winter months - on road, and mud/clay - off road).
-Mack
Current Ride: '08 Grand Cherokee 4x4
Past trucks:
2000 Cherokee Sport 4x4 :(
2004 Discovery :(
2003 F-150 4x4
79bigmack is offline   Reply With Quote
Old 01-25-2007, 12:04 PM   #2
XJLI
1993 XJ Cherokee
i've heard that autolockers up front absolutely SUCK in the snow/ice. your best bet is selectable lockers f/r or at least selectable front, powertrax rear. ive heard/read powertrax is better.
Factory Four Link
XJLI is offline   Reply With Quote
Old 01-25-2007, 12:05 PM   #3
olds442
i thought the powertrax was a locker? if not, i think the true trac is the only gear driven limited slip, i ran one and you never know its there, but its locks up great when needed
Family Wheelin...
Dad- '08 JK Rubicon- Stock, BB and 33s coming
Sister- '07 FJ Cruiser- Rear locker, BFG A/Ts
VT
Projects:
1970 Oldsmobile 442
1970 Yamaha R5
olds442 is offline   Reply With Quote
Old 01-25-2007, 12:35 PM   #4
CJ7-Tim
Go Jeepin
CJ7-Tim's Avatar
PowerTrax is a lunchbox style locker that can be installed without touching the ring and pinion gears or carrier, which gives you a lower install cost. It is a bit quiter than a lockright, but still may make some noises.
TrueTrac is a gear driven Limited Slip that replaces your open carrier and you need to reshim the carrier and transfer the ring gear over. Very quiet and smooth in the front.
Which is best depends on your budget and use of your XJ.
Driving in snow/ice with any locker or limited slip takes a little more care and attention to detail, whether it is factory TracLok or aftermarket locker/limited slip.
FOR SALE: Wide Track CJ-7 Dana 44 rear axle.
PM me for details
A Government big enough to give you everything you want, is a Government big enough to take from you
everything you have. The course of history shows that as a Government grows, Liberty decreases.
CJ7-Tim is offline   Reply With Quote
Old 01-25-2007, 01:05 PM   #5
TMCXJ
Doesn't PowerTrax make the "No-Slip" LSD lunchbox?
http://www.quadratec.com/products/76104_814.htm
http://www.off-road.com/jeep/reviews/powertrax/
Seems to me, though, that I saw them elsewhere for under $300. Maybe just my imagination, who knows...
P.S. - If it's for your 2000 remember to go 29 spline on that 8.25. Yes, I figure you already knew that but what the heck... besides, to order, you'd have to specify 27 or 29 anyhow.
"...a long habit of not thinking a thing wrong, gives it a superficial appearance of being right, and raises at first a formidable outcry in defense of custom. But tumult soon subsides. Time makes more converts than reason." Thomas Paine
TMCXJ is offline   Reply With Quote
Old 01-25-2007, 01:31 PM   #6
XJH-007
I drank what?
XJH-007's Avatar
The PT No-Slip is a great locker. I've been running one for 60K+ miles. Decent on-pavement charac. and beautiful off-road. Deff. gets tricky in snow and ice, I took mine out in the winter when my XJ was my DD.
The only beef I've heard with the Tru-Trac is if you've got a wheel off the ground it WILL just spin that wheel, you have to feather the brake to create some friction to lock it up.
Scott-Crawlorado Native
I have an addiction.....
*00' XJ_T-n-T Y-Link/6" RE_OME's_33" KM2's
Tera 4:1 / 4:56's_Elec. Locked D44
**84' CJ7 4"BDS 33's
***02 WJ Overland
XJH-007 is offline   Reply With Quote
Old 01-25-2007, 01:42 PM   #7
olds442
well of course its not a locker.......
Family Wheelin...
VT
Projects:
1970 Oldsmobile 442
1970 Yamaha R5
Old 01-25-2007, 01:47 PM   #8
XJH-007
I drank what?
XJH-007's Avatar
***02 WJ Overland
Old 01-25-2007, 01:49 PM   #9
olds442
haha um ok
Family Wheelin...
VT
Projects:
1970 Oldsmobile 442
1970 Yamaha R5
Old 01-25-2007, 03:32 PM   #10
79bigmack
So.....so it looks like TruTrac might be the better choice for the front....
Undecided on the rear....
Anyone with air-lockers ---- where do you have the buttons mounted? Can you post some pics?
tnx
-Mack
Past trucks:
2004 Discovery :(
2003 F-150 4x4
Glock Forum
