Quantcast Deep Snow/Arctic budget build - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Deep Snow/Arctic budget build
Rock Krawler Suspension's for BLOW OUT prices!!!Great deals on Mickey Thompson Tires @ Jeephut.comRCV Heavy Duty Axle Shafts Now Shipping at Baseline4x4.com
Old 11-11-2009, 02:38 PM   #1
2GPS4ME
2GPS4ME's Avatar
Does anyone know of XJs on here that have been built for deep snow, arctic wheeling, etc.?
I'm looking for pictures and some technical info on:
- TIRE sizes & makes
- Wheel sizes, backspacing
- Fender trimming
I'm looking at doing a budget setup of what I found on YouTube.
Plans are for a 2-4" lift, and a set of HUGE flotation tires.
Jeep & Toyota in deep snow video
2GPS4ME is offline   Reply With Quote
Old 11-11-2009, 04:04 PM   #2
Timo_90xj
Timo_90xj's Avatar
1990 XJ Cherokee
Something like the one below? It's those "Iceland" Jeeps that guys build there to be able to drive in winter (and wheel on deep snow and glaciers). Not that much lift usually, but wide and big dia. tires run on extremely low pressure. Wide bedlock wheels would be a good idea too.
I do not have any specs of the rig, but to me looks like around 4-5" of lift and tires are in the region of 37s or 38s.
1998 Grand Cherokee 5.9 LX, 100k miles, 1.75" BB, 32 x 11.50 BFG MT KM2s, custom- fabbed bumpers etc..
http://www.jeepforum.com/forum/f13/daily-driver-5-9-build-thread-bumpers-tube-rockers-etc-1222317/
***Under construction***
1990 XJ (4-door), 4.0 I6, AW4, NP242, PBR 42" tires, Unimog portal axles, 110" WB, full cage + uniframe completely rebuilt, front 3-link + panhard / double triangulated 4-link rear, etc...
http://www.jeepforum.com/forum/f11/hybrid-cage-build-exo-cage-internal-973910/
Timo_90xj is offline   Reply With Quote
Old 11-11-2009, 06:42 PM   #3
xj_army
i could do what they did in the vid with just my 12.50s
xj_army is offline   Reply With Quote
Old 11-11-2009, 07:20 PM   #4
Magus2727
Magus2727's Avatar
1995 XJ Cherokee
I think a 14.5" tire would be better on a 10" bead lock rim.... that way you have more flotation. you might need a little more trimming if you want to be able to stuff that wide of a tire with a "lower" lift.
NAXJA Member #2619
1995 Jeep Sport Cherokee 4x4 with an Auto and 4.0L
B&M Transmission Cooler and Autometer Tranny Temp Gauge, Ruff Stuff Diff Cover on D30.
Taraflex 1.5" BB (rear shackle only), HD Quadratec leaf springs, RE 3.5" front springs, OME Long shocks, JKS Adjustable Track Bar from K.O.R.
Daystar Control Arm Bushings, Bushwhacker Flairs, Rhino lining along bottom trim, AGR PS pump with Cooler & Filter.
Bored TB, APN Manifold, New Downpipe, Magnaflow High Flow Cat, Flowmaster Super 44.
Dual Oil Relocation Kit running two K&N301 size filters, Autometer Digital Cobalt Oil Temp and Oil Pressure Gauge.
Magus2727 is offline   Reply With Quote
Old 11-11-2009, 10:07 PM   #5
kyleboender
x2 on the 14.5" wide. They got to be pretty pricey though.
kyleboender is offline   Reply With Quote
Old 11-11-2009, 10:10 PM   #6
2GPS4ME
2GPS4ME's Avatar
The idea here is NOT to simply push snow, but to obtain a LARGE amount of flotation.
The owner of the jeep in the YouTube video said he was still riding on 2-4 feet of snow underneath the tires. 12.50s would likely dig down too fast.
I am pricing tires/wheels, and it looks like Interco has the most practical height/width combos available - for decent prices.
I like the idea of a 33x13.5-15 or a 34x14.5 on a beadlocked 10" wheel. I could likely accomplish that with little fender trimming (I'm NOT looking for flex). Air down to 3 psi, and ride the drifts...
Old 11-11-2009, 10:13 PM   #7
jjg214
i would never wheel on a glacier. there are crevasses that would eat jeeps and kill you, that you cant see til you fall through the surface.
however, for low cog you could go with 4.5" lift and do some trimming, 14.5" wide tires are gunna require aftermarket rims with low back spacing, or wider axles. i dont think you could even use stock wheels with spacers, itd be close.
WTB: HP Dana 30, Long Island/New York Area
detours backbone system for sale
jjg214 is offline   Reply With Quote
Old 11-11-2009, 10:29 PM   #8
Topgun514
1988 XJ Cherokee
I see your in south dakota but are you making a rescue jeep, or traveling to the Yukon.
btw, 2-4 inches are the lifts i see in the iceland jeeps with 14.5+ tires
87 XJ pioneer-Totalled
96 XJ Sport- Sold
Now: 88 RENIX 4.0 XJ, Project Overlander
3.5" Lift, RE SF LCA's with skids, 31x10.50R15 Duratracs, ARB Roofrack, Custom Bumper, Glasspack, Bored TB, Custom seats
Topgun514 is offline   Reply With Quote
Old 11-12-2009, 12:24 AM   #9
2GPS4ME
2GPS4ME's Avatar
I don't plan on going to any glaciers in this age. I'm simply looking for the most economical approach to navigating very deep snow. Low back-spaced wheels and 13.5-14.5 wide tires should be quite effective.
Haha, don't let the South Dakota location fool you. We've had close to 100 inches of snow the last two years, and not far away gets hit with close to 300 inches.
Old 11-13-2009, 12:04 AM   #10
2GPS4ME
2GPS4ME's Avatar
Here are a couple pictures of the ideas I'm kicking around.
Probably 32x11.50s on 10" wheels
33x13.50 baja claws
And eventually, possibly a setup similar to this...
38.5x14.50 baja claws
Old 11-13-2009, 05:28 AM   #11
fishinjeeper
thats cool!!!!
[CENTER]01 TJ. 35 inch KM2's. 4.5 RE. 2 inch body lift. dana 44. Detroit Locker. Olive Drab!! all set for trout and bambi![/CENTER]
fishinjeeper is offline   Reply With Quote
Old 11-13-2009, 06:39 AM   #12
rkates
1995 XJ Cherokee
The Ground Hawgs in the first pic come in wider sizes. The 35's are 14.5 wide and they are great in the snow. (they are rated a mud and snow tire) Plus from past experiences with them, Tire wear is very slow.
Robert
black xj
IndyORV™
http://www.indyorv.com
rkates is offline   Reply With Quote
Old 11-13-2009, 11:23 PM   #13
fishinjeeper
you could try to get something like this. i know its a wrangler, but you can get the same thing for cherokee's
Old 11-13-2009, 11:29 PM   #14
jeepster425
[YT]<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/J4Flpiyw7Ug&hl=en_US&fs=1&"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/J4Flpiyw7Ug&hl=en_US&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>[/YT]
D30 front/ D44 rear
__=====,o00o,
//__l_l_,\____\,_____
l_/-\_l__l_/-\_|
lllllll|
{o}_} {o}_}--o-}_}
jeepster425 is offline   Reply With Quote
Old 11-13-2009, 11:30 PM   #15
jeepster425
[YT]<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/bp0-qpcHc3g&hl=en_US&fs=1&"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/bp0-qpcHc3g&hl=en_US&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>[/YT]
D30 front/ D44 rear
__=====,o00o,
l_/-\_l__l_/-\_|
lllllll|
{o}_} {o}_}--o-}_}
Glock Forum
