Quantcast Death wobble when braking & @45 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Death wobble when braking & @45
Free Shipping on TIRES at KrawlOff-RoadSpartan Lockers FREE SHIPPING Excellent PricesBlack Magic Brakes - 5% Off, No Minimum Purchase Required
Old 10-07-2008, 05:38 PM   #1
Eman
i just changed out the bearings in the front of my 89 xj, because it had a light vibration @45-50mph, the driver side bearing assm. came apart when i tried to pull it off
but now when i brake i can feel pulsations in the peddle and steering wheel, and at high speeds it causes the entire jeep to shake like the entire thing is about to fall apart. and when i drive 45-50 it shakes aswell, so pretty much when trying to slow down on the highway, braking and slowing down around to 45-50 my jeep looks like a wet dog trying to dry off.
think its a warped rotor? but then why shake @50mhp?
89' Jeep Cherokee Laredo - Rough Country 4.5" Full leaf pack.
55' 4x4 Willys Wagon
- Restoration Project
Eman is offline   Reply With Quote
Old 10-07-2008, 06:22 PM   #2
1990JEEPXJ
1990 XJ Cherokee
i would check/replace the rotors and have the tires balanced
Twin 242's
The 'build' thread
1990JEEPXJ is offline   Reply With Quote
Old 10-07-2008, 06:30 PM   #3
JeepRide
Did you torque the wheel bearings on the install 175footlbs sounds like that may be your problem.
98 xj 4.0L 231 t\case off road commode
4 in the floor and a fifth under the seat
Eat more possum
JeepRide is offline   Reply With Quote
Old 10-07-2008, 07:27 PM   #4
xjfever
forum supporter
xjfever's Avatar
1995 XJ Cherokee
I would retorque the axle nut, then remove the rotors, and have them checked. if that doesn't do it next I would have the tires balanced.
  2. '99 WJ limited, 4.7L, 3" IRO lift. Bilstein shocks, JK rubicon wheels, 255/70/17's, carolina driveshaft, IRO adjustable control arms, IRO adjustable A-arm
xjfever is offline   Reply With Quote
Old 10-07-2008, 08:10 PM   #5
mofo46
1989 XJ Cherokee
i have the same damn problem and im tryin to fix it. id check your tracbar too
mofo46 is offline   Reply With Quote
Glock Forum
