death wobble help!!! - Page 2 - JeepForum.com
post #16 of 24 Old 04-07-2013, 10:11 PM
Max78
1992 XJ Cherokee
Balljoint and bushing are screwed on the trackbar?
Rockauto has acdelco trackbar for $35 and moog for $56. Autozone and checkers wanted over a hundred for their trackbars. Shipping is very reasonable.
92 Cherokee - All nude and in need of some tlc!
Max78 is offline
post #17 of 24 Old 04-08-2013, 12:35 AM
chris87xj
JF Admin
chris87xj's Avatar
1987 XJ Cherokee
Originally Posted by jlewis7168 View Post
I'm glad that I could help. I haven't had any death wobble in the last month when it used to happen every day before the tire rotation.
If having a a bad tire in front is a problem for you but having one in the rear is not, you did indeed fix the problem.
***Chris***
chris87xj is offline
post #18 of 24 Old 04-16-2013, 11:09 AM
supernas
1990 XJ Cherokee
dude what autozone did you go to
Duralast/Track Bar
Part Number: DS1147
Alternate Part Number: DS1147
Warranty: Limited Lifetime
Notes: Front suspension
Price: $35.99
supernas is offline
post #19 of 24 Old 04-16-2013, 11:22 AM
Max78
1992 XJ Cherokee
Duralast/Track Bar
Part Number: DS1147
Price: $35.99
The closest one to my house. . .
Autozone Trackbar for my Jeep = $103.99
I also bought a Bosch O2 sensor from rock auto for $25, AZ wanted $50. . . I never buy from them unless Its a dire emergency.
Edit: The track bar you posted says it does not fit my 92, or a 97 Cherokee on AZ site?
Edit 2: Lol the trackbar you posted will only fit 84-90 Jeeps, the PO is in a 97 Cherokee, so different track bar.
Max78 is offline
post #20 of 24 Old 04-16-2013, 04:35 PM
supernas
1990 XJ Cherokee
hmm is the ball joint on the 92's on the passenger side?
also I know that there are different prices in different areas but man that part that calls for your jeep here is 89.99
supernas is offline
post #21 of 24 Old 04-17-2013, 09:02 AM
Max78
1992 XJ Cherokee
No its a rubber bushing with metal sleeve. I knew there where different prices depending on region, its only $14 so not to bad.
Max78 is offline
post #22 of 24 Old 04-18-2013, 08:53 AM Thread Starter
cherokeetina220
1997 XJ Cherokee
92? Whered that come from? My jeep is a 97 lol! I gotta save up for these damn parts. Its like fml what else can go wrong? Once I fix it then im going to save up for a lift kit. Any cheap lift kits for 97 Cherokee?
cherokeetina220 is offline
post #23 of 24 Old 04-18-2013, 12:19 PM
Max78
1992 XJ Cherokee
The track bar is the same form 91 to 2001 so we are talking about the same part for your jeep. It can be had for $35, same with the steering damper, and its $20-$25.
Define cheap lift kit? Do you want a budged boost? It's spring spacers and a shackle, or AAL. they can be had for rather cheap.
Max78 is offline
post #24 of 24 Old 06-12-2013, 02:51 PM Thread Starter
cherokeetina220
1997 XJ Cherokee
Death wobble almost cured!!! I only needed 2 parts my driver cv axle and my steering stabilizer link. Everything else was fine and I switched my back tires to the front. I'm so relieved!!
