death wobble help!!! - JeepForum.com
post #1 of 24 Old 04-05-2013, 08:52 AM Thread Starter
cherokeetina220
1997 XJ Cherokee
I have serious vibrations coming from my front left tire. I know its the death wobble.im freaking out because what do I have to do to fix this?? Do I need a new track bar? Bushings? And my jeep is stock and not lifted. Please help!
cherokeetina220 is offline
post #2 of 24 Old 04-05-2013, 09:23 AM
Max78
1992 XJ Cherokee
Well, there are quite a few things that could cause DW, so step back and take a good look at your vehicle. We cannot tell you what is causing your DW, we can only guess.
DW is not really a vibration, it’s more like driving along all fine, hit a bump and your jeep as a seizure, or basically the front end will shake left right. So maybe your tires are out of balance?
If that's not it then get under the vehicle and inspect for warn or damaged parts. If you cannot see any visibly warn parts then have someone manipulate the steering wheel and check for abnormal movement, pay close attention to the track bar at both the ball joint and bushing end. If that all checks out inspect the frame area around the trackbar bracket and check for cracks or loose hardware. If all of that is fine then what kind of condition are your shocks in? When is the last time they were replaced? Shocks do not last forever.
There are a few other things that could cause DW but these are the basics. . .
Good luck and let us know what you find.
92 Cherokee - All nude and in need of some tlc!
Max78 is offline
post #3 of 24 Old 04-05-2013, 09:29 AM
eprovenzano
2005 WK
On my son's XJ we changed ball joints, but still had DW. We found the track bar had elongated its mounting hole. We pulled the TB bolt, added a washer and re-tightened the bolt. The washer was then welded to the jeep... no more DW.
I didn't think that was the issue, but after reading and reading posts on DW, the track bar seems to be the biggest culprit.
2012 Grand Cherokee Limited Wk2 (Momma's)
2005 Grand Cherokee Limited, WK, 4.7 V8 currently rolling on Cooper Discovery 265 70 17's, with 1.25" spacers.,installed an OME HD lift sourced through Kolak.
1996 XJ 6 inch lift on 33's (Son's)
eprovenzano is offline
post #4 of 24 Old 04-05-2013, 09:34 AM
jeepnphreak
1989 XJ Cherokee
DW culprits from my personal exp.
Tie rod ends.
Track bar
Ball Joints
Tires need balencing.
The stering stabolizer(the shock absorber on the tierod to axle)
1989 XJ, 5spd, np231 with bjconversion SYE , re3.5, 33x12.5r15 BFgoodrich ATS, D30 F, Dana 44 from 87 with 4.56s, Custom front bumper.
94 yj: stock everything and 4 angry squarrels under the hood.
jeepnphreak is offline
post #5 of 24 Old 04-05-2013, 04:43 PM
foggybottombob
DW is when both tires shake back and forth violently in unison. You won't get DW on one tire.
foggybottombob is offline
post #6 of 24 Old 04-05-2013, 05:36 PM
Timo_90xj
Timo_90xj's Avatar
No, you don't know DW is not just one tire and you don't really know it comes from one specific location. DW is something that literally tries to shake your vehicle into pieces.
If you know the vibes are from left front, go get it balanced, or check for bad/ broken bead or ply.
***Under construction***
Timo_90xj is offline
post #7 of 24 Old 04-05-2013, 05:44 PM
Purcell69
A vibration or shaking from one tire typically is a balance issue, a tire that the tread is starting to separate, or, in rare cases, a bent rim. If the tread is starting to separate, the tire will show wear on one portion of the tread more so than the rest. It may also be apparent when driving slowly across a smooth surface, as you can feel one corner of the vehicle rise and fall with the bad spot in the tire. At higher speeds, it becomes a vibration, similar to a tire out of balance, and may have a thumping sound with it as the tire goes down the road. If you suspect a bad tire, pull the wheel and have it run on the spin balancer. Look toward the face of the wheel and note if there is any visible "hopping" at the top of the tire as it passes.
-Joe
Purcell69 is offline
post #8 of 24 Old 04-05-2013, 10:00 PM
chris87xj
JF Admin
chris87xj's Avatar
1987 XJ Cherokee
Welcome to jeepforum Tina!
It does sound more like a problem with the one tire to me. Get it checked out.
***Chris***
chris87xj is online now
post #9 of 24 Old 04-06-2013, 10:18 AM
habbyguy
Swap the left side tires front to back and see if the symptoms change. Check the left front shock (bad bushings can cause some pretty "interesting" vibrations if the tire's a little out of balance). An unbalanced wheel alone should NEVER cause DW unless it's out of balance by a whole lot - it normally takes some play in the system to create a DW or even "bad vibration" situation (in my case, it was a bad shock).
habbyguy is offline
post #10 of 24 Old 04-06-2013, 06:23 PM
booman75
1979 CJ5
I have been having similar issues with this.. i would get at a certain speed it would go into a seizure lol i could see the left side but never was able to check passenger side..even sometimes if i hit a bump would cause it.. had left side an others rebalanced checked for worn parts have replaced most of them came down to the stablizer shock ( shimmy shock ) replaced it so far so good.
booman75 is offline
post #11 of 24 Old 04-07-2013, 08:50 AM
habbyguy
Hi, booman75 - I'll be the first to point out that the "problem" is never the steering stabilizer, but it reduces the tendency of some other problem to "build" all the way up to DW. I'm afraid you're going to still have to track down the issue someday after that new stabilizer wears out a little...
habbyguy is offline
post #12 of 24 Old 04-07-2013, 01:44 PM
jlewis7168
rotate both of the tires from the front to the back. That fixed my problem. my front passenger tire was bad.
jlewis7168 is offline
post #13 of 24 Old 04-07-2013, 02:27 PM
chris87xj
JF Admin
chris87xj's Avatar
1987 XJ Cherokee
*That fixed my problem.
well kinda for now anyways lol.
***Chris***
post #14 of 24 Old 04-07-2013, 07:42 PM
jlewis7168
I'm glad that I could help. I haven't had any death wobble in the last month when it used to happen every day before the tire rotation.
post #15 of 24 Old 04-07-2013, 08:57 PM Thread Starter
cherokeetina220
1997 XJ Cherokee
figured out why I have death wobble
Well my buddy who used to work at a jeep dealership looked underneath my front end and said that the ball joint and bushing is screwed.so I gotta fix that.as for the track bar he thinks it might be ok.and eventually im going to have to fix the steering stabilizer. So there we go now to get the cabbage to fix this crap!!
