Death wobble at 45mph when braking? - JeepForum.com
post #1 of 9 Old 11-21-2012, 11:42 AM Thread Starter
Jeepnbo
Just had my rims and tires balanced rotated thinking itd take care of my death wobble when i hit my brakes. It only does it when i hit my brakes and im pretty much ruleing out warped rotors as it only happends at 45 mph. Control arm bushings or track bar?
Jeepnbo is offline
post #2 of 9 Old 11-21-2012, 11:45 AM
WhiteOut
WhiteOut's Avatar
Warped rotors.
WhiteOut is offline
post #3 of 9 Old 11-21-2012, 11:56 AM Thread Starter
Jeepnbo
Not throwing it out the window but if they were warped wouldnd it happen at other times then just at 45?
Jeepnbo is offline
post #4 of 9 Old 11-21-2012, 12:41 PM
WhiteOut
WhiteOut's Avatar
If it only happens when you are braking, it is brake related.
WhiteOut is offline
post #5 of 9 Old 11-21-2012, 02:03 PM
jjshbetz11
Had this problem with my 96, he is correct it's the rotors, replace pads as well
sent from a flat black thingie
R.I.P 96 xj aka. War Queen
Hello 2000xj
jjshbetz11 is offline
post #6 of 9 Old 11-21-2012, 02:08 PM Thread Starter
Jeepnbo
interesting as i did look at my rotors today and seen they will need to replaced soon. Thanks for yours guys input.
Jeepnbo is offline
post #7 of 9 Old 11-21-2012, 02:33 PM
Paradise XJ
1988 MJ Comanche
EZ to fix/ rule out.
Either take them off and have them resurfaced...or replace them. If you take them to have them resurfaced...they'll probably tell you they're warped or played out.
Could also be rear brakes. The rear drums on my Nissan were shot...but it felt like the front end...weird, but true.
1990 XJ Laredo - White & Chrome
1988 MJ Pioneer - Metallic Green and Black
Paradise XJ is offline
post #8 of 9 Old 11-21-2012, 03:28 PM Thread Starter
Jeepnbo
Yes very ture. I'll replace them as i already have 2 sets of pads layin around so hopefully itll resolve my issue. I hope it isnt the drums as i already had them gone threw.
Jeepnbo is offline
post #9 of 9 Old 11-21-2012, 05:41 PM
jjshbetz11
If its your rear breaks I would assume you have worn bushings or else somewhere in your suspension up front allowing your front axle to move sideways. I would go through the front susp. And look for loose bolts, just use a torque wrench...... Tightened my track bar bolt on axle and snapped that mutha.... Not a good time hack sawing through the bolt.....
Hello 2000xj
