Quantcast Death Shake when applying Brakes - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Death Shake when applying Brakes
Truck-Lite's New LED Headlamp SeriesGR8TOPS Introduces the Exogate HD Tire CarrierRUBICON EXPRESS Lift Kits and Accessories Available at Bas
Old 06-30-2007, 12:26 AM   #1
JTrue
Well I deliver pizzas and have been going through rotors really quickly because all of the driving I do. Anyways, lately when I brake from around 50 or faster I get a very bad shaking from the the front end. It usually goes away when I let off the brakes but sometimes this will happen when I go over a big bump. It feels like one of my wheels is wobbling and about to fall off. Really scary.... Could a bad alignment combined with warped rotors cause a violent shaking like this? I have noticed one of my front tires is wearing on the outside edge alot faster then the other, although the rig still tracks straight. I also thought maybe one of my tie rod ends was about to go, so I jacked up the front end, but can feel no play at all. I am at a loss, I will probably replace the rotors since I have a 2 year warranty on them as well as get an alignment. Anything that I am missing? Thanks.
JTrue is offline   Reply With Quote
Old 06-30-2007, 12:30 AM   #2
balloo93
Little Red Menace
balloo93's Avatar
1993 XJ Cherokee
Check your ball joints. Jack each side up seperately and pay close attendtion to the ball joints. If the top of the knuckle pulls up and away from the ball joint then they are bad, Once up, push against the top of the tire and feel for looseness. There should be none at all.
Make sure the lug nuts are torqued to 100ft/lbs and not more than that. Too much torque on teh nuts will lead to warping.
93 Sport
Beer is proof that God loves us and wants us to be happy............Ben Franklin
Specs in Profile.
http://www.cardomain.com/ride/325707/1
http://www.cardomain.com/ride/2406854/1
balloo93 is offline   Reply With Quote
Old 06-30-2007, 12:34 AM   #3
NinjaofDoom
1990 XJ Cherokee
in my daytona when i got my tires rebalanced the brakeshaking stopped
There was the episode where I threw my shoe at the enemy, like this!.... my foots cold.
NinjaofDoom is offline   Reply With Quote
Glock Forum
