Quantcast death shake at 45+ - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > death shake at 45+
Spartan Lockers FREE SHIPPING Excellent PricesBlack Magic Brakes - 5% Off, No Minimum Purchase RequiredDISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-
Old 09-10-2007, 12:24 PM   #16
jjcustoms09
what is a BW? and my jeep will 90% stop the vibes when i go fast dont know why but like right around 40-55 thats when its REAL bad and my RIGHT tires will look like its kinda hoping off the ground i maid sure all the lugs where tight and they where.
Originally Posted by Flexin' XJ
Since it does it with different tires on, I suggest looking at your trac-bar mount at the body. If that joint is loose, your axle will move side to side. I agree with EricsXJ about the DW thing. DW won't go away the faster you go. The axle gets into a back and forth motion that won't stop until you stop. I had it on my XJ. At 45 it would shake violently and other cars would slow because they could see it happening.
Found my Trac-bar bracket was loose at the axle and causing the axle to move. Tightened it and it went away but my upper mount is toast. Now I have a tire balance issue too that needs to be take care of. Which more than likely is a bent rim since I have had them balanced recently and it didn't help.
jjcustoms09 is offline   Reply With Quote
Old 09-10-2007, 08:33 PM   #18
EricsXJ
The Post man
EricsXJ's Avatar
Originally Posted by jjcustoms09
it is not my tires ive put my stock ones on still does it put my mud tires on still does it put my smaller mud tires on still will do it. all them are with different rims to so i know damn well it aint the tires.
could it be that shock type looking thing on my trac bar or what ever you call it.?
It could also be an out of balance driveshaft... You can easily troubleshoot this by removing the front - test drive - reinstall, remove the rear - test drive - and see if anything changes.
Otherwise if you are sure its not those then go ahead and troubleshoot it like DW until you find and fix the problem. No harm in that but it just doesn't sound like DW to me... Start with the trackbar. Then go to (in whatever order you want) ball joints, steering joints, control arm bushings, alignment. And I'll throw in there engine mounts and transmission mounts for good measure.
Eric
2000 XJ "PROJECT RUBICON" lifted, locked, shafted, running 35's, 4.56 gears, pair of ARB's, and stock AM/FM cassette
My website - EricsXJ.com
EricsXJ is offline   Reply With Quote
Old 09-11-2007, 05:10 AM   #19
Flexin' XJ
1995 XJ Cherokee
what is a BW?
DW = Death Wobble
BW = ???
If your tire is hopping off the ground, it sounds like a wheel/tire balance issue. But I don't know why it still does it with different wheels/tires.
It is possible an axleshaft is out of balance or out of round as mecompco mentioned.
1995 Cherokee 4-Door
4.0 AW4
4.5" RC System
JKS Discos
JKS Adjustable Track Bar
JCR 1-Ton Steering Conversion
Edelbrock Ceramic Header w/full 2.5" exhaust
33x12.50x15 SSRs
Aussie in front, LSD in rear
Death Wobble
Member GLFWDA
Flexin' XJ is offline   Reply With Quote
Glock Forum
