Quantcast death shake at 45+ - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > death shake at 45+
Great deals on Mickey Thompson Tires @ Jeephut.comOfficial Chassis Saver Rust Preventive Truck & Auto UnTJ 5.25" Speaker Adapters - NalinMFG
Old 09-09-2007, 05:46 AM   #1
jjcustoms09
death shake at 45+
ok i have a 89 jeep cherakee with a 3inch heckthorn lift and 33s and i have this death shake every time i hit 40MPH if i speed up to like 55 it will go away i dont know what i can do to fix this problem. i mean like the hole front end with shake at them speeds then go away? and thats not safe.
any one know what i can do to fix this problem?
jjcustoms09 is offline   Reply With Quote
Old 09-09-2007, 08:12 AM   #2
cobra
1987 XJ Cherokee
check your trackbar bushing might be shot, or it can be loose
cobra is offline   Reply With Quote
Old 09-09-2007, 08:42 AM   #3
jdhughes
i balanced my wheels, and that fixed mine
jdhughes is offline   Reply With Quote
Old 09-09-2007, 09:33 AM   #4
hillbilly67
The death wobble is caused by not enough caster, you need to kick the bottom of the axle forward. Worn and loose components amplify it, but are not the cause. I've been curing the same problem on Dodge pickups (which use the same style of front end) for 5 yrs now. Dodge sent the trucks out set at 0 degrees, I've cranked some up to 10 to get rid of it.
Once a lift is installed, the arms usually pull the bottom of the axle back. The problem then is trying to add caster while keeping the pinion angle decent. After receiving so many complaints, we are now working with American Axle to custom build offset kingpin yokes to cure this.
hillbilly67 is offline   Reply With Quote
Old 09-09-2007, 12:22 PM   #5
pgdyk
1988 XJ Cherokee
Sounds expensive. What about those of us who have the same problems without a lift and balanced stock size tires?
88 XJ 194K 4x4
84 Dodge Ramcharger 4x4
pgdyk is offline   Reply With Quote
Old 09-09-2007, 05:18 PM   #6
cj7guy
Agreed, I get it on my bone stocker.
Any tips? Should I have my mechanic set my alignment a particular way, more or less toe?
LCAs aren't really an option unless I go for a 3" lift. How else can I adjust it?
cj7guy is offline   Reply With Quote
Old 09-09-2007, 07:42 PM   #7
foreman1063
Pull out your tape measure and check the toe. You want the front toed in about 1/8th of an inch.
foreman1063 is offline   Reply With Quote
Old 09-09-2007, 10:01 PM   #8
cj7guy
Any way to adjust caster on a bone stock Jeep?
Would 1/4" toe-in be better?
Old 09-09-2007, 11:28 PM   #9
EricsXJ
The Post man
EricsXJ's Avatar
First of all what this guy has is NOT death wobble.
Death wobble rarely is as predictable as this (doesn't happen every time at the exact speed, etc) and it does not go away by going faster!
This is surely a bad tire/wheel balancing issue. I've experienced it myself and just because the vibrations are bad does not mean its the same as DW. In my case I could not go above 50 mph. Same vibes every time.
To the original poster, you need at the minimum a balance job. If that doesn't fix it completely, maybe your wheels need to be replaced or the tires if they are out-of-round. If you want to experiment before balancing them you can just rotate them yourself and see how that changes things as the individual tires are usually at different levels of unbalance. Sometimes this can help you determine which wheel/tire is the worst, but in your case its going to need a balancing regardless.
Eric
2000 XJ "PROJECT RUBICON" lifted, locked, shafted, running 35's, 4.56 gears, pair of ARB's, and stock AM/FM cassette
My website - EricsXJ.com
EricsXJ is offline   Reply With Quote
Old 09-09-2007, 11:34 PM   #10
EricsXJ
The Post man
EricsXJ's Avatar
True for Dodge pickups maybe, but I disagree in our case unless the Jeep in question has zero degrees caster, which is unheard of. It is very common to have less caster than factory spec after instalation of a lift but it will not automatically cause DW. I will agree that it is a contributor. In what we've experienced a loss or worn part is almost always the cause, which is why you can have caster set to factory specs and still get DW.
Eric
Old 09-09-2007, 11:49 PM   #11
EricsXJ
The Post man
EricsXJ's Avatar
This is true Death Wobble (from thread http://www.jeepforum.com/forum/f11/stock-cherokee-death-wobble-460301/ ):
My 99 cherokee sport does a death wobble when i hit any large bumps at about 50+ mph, i need to come to a complete stop or almost a complete stop to make it go away. It's pretty bad, my car is still relatively low mileage i don't understand! please reply!!!
Eric
Old 09-10-2007, 01:33 AM   #12
pgdyk
1988 XJ Cherokee
I fixed my DW, shift fast and hold onto the wheel tight until i hit 60.
88 XJ 194K 4x4
Old 09-10-2007, 03:53 AM   #13
jjcustoms09
it is not my tires ive put my stock ones on still does it put my mud tires on still does it put my smaller mud tires on still will do it. all them are with different rims to so i know damn well it aint the tires.
could it be that shock type looking thing on my trac bar or what ever you call it.?
Old 09-10-2007, 10:12 AM   #14
mecompco
www.midcoastjeep.com
mecompco's Avatar
1994 XJ Cherokee
After eliminating the DW by adjusting the LCAs, I still had front driveline vibes at 55+ (the faster the speed, the worse they got). It turns out the garage had not properly seated the U-Joint exactly in the yoke (or, the yoke is slightly sprung) and it was off to one side just a tiny bit. In any case, we removed the straps, tapped the U-Joint with a brass hammer to seat it, tightened it back up and the vibes were totally gone. I plan to replace the front yoke with a U-bolt style eventually, but it's working fine for now.
'94 Cherokee Country
Engine: 4.0 HO, Sealed canister filter, 3 core CSF steel radiator, CatCo cat, Dynomax Turbo Flow muffler.
Electronics: Remote start/locks, Pioneer DEH-P7800MP w/XM, Polk Audio speakers, Garmin Nuvi 660 GPS, Cobra 148 GTL P&T w/Wilson 1000.
Suspension: Old Man Emu 3" lift+OME AAL, JKS adjustable trackbar, QDs, LCAs UCAs, A.C.O.S., DPG Offroad adjustable bumpstop plate, Daystar poly bumpstops.
Steering: Currie HD steering, C-ROK steering box reinforcement, OME stabilizer.
Armor/Recovery: T&T Custom belly skid, Mopar gas tank skid, JKS LCA mini skids, Rock Lizard Super Skink Sliders, Mopar 2" receiver, ARB Bull Bar/Ramsey REP 8.5 winch.
Drive train: D30 front axle w/Superior Chromo D30 axles & outter seals, D/S 4.56 R&P, ARB locker, Ruff Stuff cover. Ford 8.8 rear axle w/Superior Super 88 kit, Ford Motor Sports 4.56 R&P, ARB locker, SOLID cover, Russell stainless lines. Front and rear Tom Woods HD drive shafts, 242 x-fer case w/Tom Woods SYE.
Tires/Wheels: 33x10.5x15 BFG Mud Terrains on Alcoas.
Misc: Garvin Wilderness rack, Safari Snorkel, Redline Tuning hood lifts.
Awaiting installation: Autometer A pillar gauge pod, oil, water, & tranny temp guages, PIAA driving lights, Goferit tie-rod flip bushing, '95 Brake booster and M/C, M.O.R.E. Motor mounts, TnT Custom 1.5" Shackle.
Stroker Project: HO Block, '99 intake manifold, bored TB, 1" TB spacer, Dynomax Blackjack Header, Permacool electric fan.
mecompco is offline   Reply With Quote
Old 09-10-2007, 12:01 PM   #15
Flexin' XJ
1995 XJ Cherokee
Since it does it with different tires on, I suggest looking at your trac-bar mount at the body. If that joint is loose, your axle will move side to side. I agree with EricsXJ about the DW thing. DW won't go away the faster you go. The axle gets into a back and forth motion that won't stop until you stop. I had it on my XJ. At 45 it would shake violently and other cars would slow because they could see it happening.
Found my Trac-bar bracket was loose at the axle and causing the axle to move. Tightened it and it went away but my upper mount is toast. Now I have a tire balance issue too that needs to be take care of. Which more than likely is a bent rim since I have had them balanced recently and it didn't help.
1995 Cherokee 4-Door
4.0 AW4
4.5" RC System
JKS Discos
JKS Adjustable Track Bar
JCR 1-Ton Steering Conversion
Edelbrock Ceramic Header w/full 2.5" exhaust
33x12.50x15 SSRs
Aussie in front, LSD in rear
Death Wobble
Member GLFWDA
Flexin' XJ is offline   Reply With Quote
Glock Forum
