Quantcast death shake - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > death shake
JcrOffroad new Crusader TJ/YJ/CJ Bumpers available!!JKS products - Free shipping! Lowest prices!East Coast Gear Supply- Quality Diff Parts
Old 07-23-2007, 10:28 PM   #1
vtjeeps
death shake
Ok we installed the 4.5 lift in the 2000 xj i just put a new track arm on and a new universal . took for the first ride shakes so much almost go off the road. i need some more help any would be great . I am lost for answers
vtjeeps is offline   Reply With Quote
Old 07-23-2007, 10:30 PM   #2
XJK
The Guru of Nothing
XJK's Avatar
did you have it aligned?
do you have a SYE?
the lack of either one of these at that height will tend to cause a very large amount of vibrations.
-Kyle
XJK is offline   Reply With Quote
Old 07-24-2007, 05:37 AM   #3
vtjeeps
no vibrations shakkking
we dropped the trans . and it shakes so much when u hit a bump the tires chirp .
Old 07-24-2007, 09:31 AM   #4
laurxj
1991 XJ Cherokee
transfer case drop(temporary fix) or just put a SYE in. at that height you really need it.
is the trac bar tight?
did youg et an alignment?
you dropped the trans??
1991 XJ 4.5'' RE Super-Flex 31'' M/Ts on Cragar soft 8s..tons of other mods
1979 Pontiac Trans Am
1979 Monte Carlo
1974 Camaro worked 350, TH350 finished Summer 08...new obsession
2003 TJ 5spd...the new DD
laurxj is offline   Reply With Quote
Old 07-24-2007, 10:02 AM   #5
XJK
The Guru of Nothing
XJK's Avatar
the hitting the bump and tires chirping is due to you not having an alignment. also did you get an adj tracbar?
and i hope by you saying you dropped the trans you meant transfer case.
-Kyle
Old 07-24-2007, 04:13 PM   #6
vtjeeps
ok
yes i droped the transfercase and it shook and chirped before the lift i was hopping with new lower control arms and bushings it would help things. yes i put a new trac bar in .. im not sure about the alignment because all that changed was the caster so it would make the steering touchy not throw the front end around .i gess im going to changed all the ball joints and tie rods and hope that fixes it..
Old 07-25-2007, 01:21 PM   #7
Kuasimodem
With the stock steering system, when you raise the body in relation to the axle without aligning the front end it will toe the front wheels in. That is why an alignment is required when a lift is installed.
Get the alignment done, then start replacing parts if it still has death wobble.
White Jeep Club Member #1992
Original Rust Jeep Club Member #5!
Old Guy Jeep Club Member #1992
"The most terrifying words in the English language are: I'm from the government and I'm here to help." - Ronald Reagan
Kuasimodem is offline   Reply With Quote
Old 07-25-2007, 03:37 PM   #8
vtjeeps
yes yes but
well i would get it dune but needs ball joints so waist of time till i get them in rite rite..
Old 07-26-2007, 09:34 AM   #9
mecompco
www.midcoastjeep.com
mecompco's Avatar
1994 XJ Cherokee
You need to get ALL your front end parts in good shape, and a professional alignment BEFORE trying to track down death wobble (you may even find it is no longer an issue).
Excessive caster can cause problems as it also effects DS angle. According to the FSM, proper DS angle has precedence over caster angle. Acceptable caster is 5* to 9*.
'94 Cherokee Country
Engine: 4.0 HO, Sealed canister filter, 3 core CSF steel radiator, CatCo cat, Dynomax Turbo Flow muffler.
Electronics: Remote start/locks, Pioneer DEH-P7800MP w/XM, Polk Audio speakers, Garmin Nuvi 660 GPS, Cobra 148 GTL P&T w/Wilson 1000.
Suspension: Old Man Emu 3" lift+OME AAL, JKS adjustable trackbar, QDs, LCAs UCAs, A.C.O.S., DPG Offroad adjustable bumpstop plate, Daystar poly bumpstops.
Steering: Currie HD steering, C-ROK steering box reinforcement, OME stabilizer.
Armor/Recovery: T&T Custom belly skid, Mopar gas tank skid, JKS LCA mini skids, Rock Lizard Super Skink Sliders, Mopar 2" receiver, ARB Bull Bar/Ramsey REP 8.5 winch.
Drive train: D30 front axle w/Superior Chromo D30 axles & outter seals, D/S 4.56 R&P, ARB locker, Ruff Stuff cover. Ford 8.8 rear axle w/Superior Super 88 kit, Ford Motor Sports 4.56 R&P, ARB locker, SOLID cover, Russell stainless lines. Front and rear Tom Woods HD drive shafts, 242 x-fer case w/Tom Woods SYE.
Tires/Wheels: 33x10.5x15 BFG Mud Terrains on Alcoas.
Misc: Garvin Wilderness rack, Safari Snorkel, Redline Tuning hood lifts.
Awaiting installation: Autometer A pillar gauge pod, oil, water, & tranny temp guages, PIAA driving lights, Goferit tie-rod flip bushing, '95 Brake booster and M/C, M.O.R.E. Motor mounts, TnT Custom 1.5" Shackle.
Stroker Project: HO Block, '99 intake manifold, bored TB, 1" TB spacer, Dynomax Blackjack Header, Permacool electric fan.
mecompco is offline   Reply With Quote
Old 07-26-2007, 04:17 PM   #10
vtjeeps
solved
well last night got all the parts, 2 ball joints all tie rods and new stabilizer .. got dune took it for a drive all fixed hahaha.. what the hell
Old 07-26-2007, 04:41 PM   #11
XJK
The Guru of Nothing
XJK's Avatar
did you get it aligned? make sure you get it aligned aswell, but congrats on the fix
-Kyle
Glock Forum
