Death Rattle of Death: Part Deux - JeepForum.com
post #1 of 4 Old 01-09-2005, 05:32 PM Thread Starter
BurlySurly
BurlySurly's Avatar
For Part 1:
http://www.jeepforum.com/forum/showt...t=death+rattle
Alright, so I went through all of the steps given to me in that last thread and didnt find fix the thing, so I dropped the trans, and took off the torque converter and the flexplate and WOW, the flexplate was cracked all the way around and was wobbling back and forth, thats what was causing the DEATH RATTLE of DEATH after all.
So I got a new one, and installed it AND NOW IT WONT START!!!!
But one thing i noticed before the install was that the pattern of cutaway sections of steel around the edges of the plate were different than the ones on the stock plate, I checked my Haynes manual, which said the sensor on the bell housing read the teeth off the flywheel, not the cutaway areas, and the rest was identical. Could Haynes have steered me wrong and could this sensor be stopping my Heep from starting?
I have done so much work on this thing in the past couple weeks and I need it to run. When I try to start the vehicle, it just sounds like the timing is WAY off, and yes, I am getting spark and fuel. Im so confused.
EDIT: I also put in a new rear main seal, oil pump, trans filter, trans seals, pan seals for engine and trans, new plugs wires, etc. etc. etc...
I'll paypal anyone who correctly identifies my problem $5 seriously.
I am getting ****ing tired of this.
Necropheliac Jeep Club: Member #1
'93 XJ
4.0 Inline 6
2 Door
Automatic
....mods coming soon, I swear.
BurlySurly is offline
post #2 of 4 Old 01-09-2005, 05:43 PM
creeperjeep
Ill be willing to bet that the problem is with the crank angle sensor on the back of the motor above the bell housing, mabey there is metal in the sensor, or it is jarred loose, take a good look at it
-matt
creeperjeep is offline
post #3 of 4 Old 01-09-2005, 06:02 PM Thread Starter
BurlySurly
BurlySurly's Avatar
The only way that sensor is busted is if I did it in taking the trans out, because it started before I did all this work. Ill give it a look.
'93 XJ
4.0 Inline 6
2 Door
Automatic
post #4 of 4 Old 01-11-2005, 01:55 PM Thread Starter
BurlySurly
BurlySurly's Avatar
Ok, well, turns out the flywheel/flexplate from a 1990 will not work on 1993 becuase the crank angle sensor reads the grooves in the back, which are slightly different.
Now Ive got another problem.
Neither Autozone nor Advance Auto carry that part for a 93, I have no idea why. Anyone know of someplace besides a dealer or scrapyard that would?
Anyone got a tranny out right now any want to sell me theirs?
'93 XJ
4.0 Inline 6
2 Door
Automatic
CV Driveshaft Rebuild Part Deux sharpie XJ Cherokee Technical Forum 28 03-26-2014 03:06 AM
Death Rattle 4x4cherokee6 XJ Cherokee Technical Forum 7 02-19-2005 01:10 PM
Death Rattle of Death... BurlySurly XJ Cherokee Technical Forum 12 02-07-2005 03:28 PM
strange leak, part DEUX!? xjrubicon XJ Cherokee Technical Forum 10 12-17-2004 08:05 AM
New Cherokee owner - death rattle...how to deal?? ratter XJ Cherokee Technical Forum 7 09-24-2003 09:29 AM
