Death Rattle of Death... - JeepForum.com
post #1 of 13 Old 12-14-2004, 11:11 AM Thread Starter
BurlySurly
BurlySurly's Avatar
Ok guys, need some diagnosis help here. My searches have yielded nothing, and I know you guys know some stuff.
My jeep makes a clackity-clackity-clack whenever I am idling and it goes away as my RPMs begin to rise. It has done this for a while, but also went away for about a month and then came back.
I though it sounded like the fan hitting a shroud or something for the longest time, but its not. As i raise up the hood, its coming from what sounds like the back of the engine/ front of the tranny, but Im not sure.
It runs fine, shifts fine, gets good gas mileage. It just makes the crazy racket. What should I do, short of taking it to a mechanic?
Any idea what the sound is or how to fix it? Like i said, it totally goes away as I start driving, and the clackity-clacking goes up with the RPMs then simply goes away. Im stumped.
Necropheliac Jeep Club: Member #1
'93 XJ
4.0 Inline 6
2 Door
Automatic
....mods coming soon, I swear.
BurlySurly is offline
post #2 of 13 Old 12-14-2004, 11:25 AM
xj4play
xj4play's Avatar
2004 KJ Liberty
Mine was making a similar noise, more of a rattling sound, coming from the same area. It turned out to be the tranny mount, it was WAY hosed.
There is a bracket that attaches to the mounting bolts where the TM meets the tranny housing. That bracket supports the cat, so as the tranny was moving/vibrating due to the bad TM, the cat was moving along with it and rattling against the undercarriage.
If you have never replaced the TM, it is probably overdue. They're cheap and easy to install, it's worth the effort, believe me!
Good luck!
Leave no bolt unturned...
1998 ZJ Laredo
4.0 IL6, 42RE Tranny, 242 TC, 2" lift, Cragar Soft 8's, 30" BFG All Terrains
xj4play is offline
post #3 of 13 Old 12-14-2004, 11:28 AM Thread Starter
BurlySurly
BurlySurly's Avatar
Im gunna go and check that now, but being underneath it while running, I didnt notice any vibration.
Ive also checked the cat conv. like some guy on here was having problems with, and thats DEFINITELY not it.
BRB.
'93 XJ
4.0 Inline 6
2 Door
Automatic
post #4 of 13 Old 12-14-2004, 11:40 AM Thread Starter
BurlySurly
BurlySurly's Avatar
Ok, all the mounts seem solid. There is literally no vibration and everything seems to be running smooth. It just sounds as if its in the very front of the tranny from what I can tell.
its an automatic, what could be wrong that would cause such a noise?
Someone said something to me about a "flywheel" screw up or something, do automatics have flywheels even?
Any suggestions would be cool.
'93 XJ
4.0 Inline 6
2 Door
Automatic
post #5 of 13 Old 12-14-2004, 11:49 AM
xj4play
xj4play's Avatar
2004 KJ Liberty
When I was chasing down the noise, I thought the same thing, the tranny mount looks good, I didn't see any movement. But one day, I decided since I had already done the motor mounts, I'd better do the tranny mount as well. After all, it had been exposed to oil leaks, weather, etc. for better than a quarter million miles. As it turned out, the rubber was badly deteriorated and allowing the tranny to move just enough to piss me off with that gawd-awful noise.
Keep in mind, XJ's love to eat motor mounts and tranny mounts...
I've also heard stories of the flex plate/flywheel bolts working loose (automatic=flex plate, manual=flywheel). You might try tightening them up.
1998 ZJ Laredo
xj4play is offline
post #6 of 13 Old 12-14-2004, 11:55 AM Thread Starter
BurlySurly
BurlySurly's Avatar
alright, well, im going to be replacing a seal here pretty soon anyhow, any immediate danger to driving it as-is for another couple weeks (bear in mind, its been doing this for a while) until I have to drop the tranny anyway? Or should I go ahead and order the parts and get it done?
EDIT: And also, my cat is not moving at all, so do you think that's still the problem, as its not tapping my under carriage at all?
'93 XJ
4.0 Inline 6
2 Door
Automatic
post #7 of 13 Old 12-14-2004, 11:57 AM
scubaguy19
I've had this same problem(I think) i've never heard of anyone else having it before, but my torque converter bolts came loose, doesn't take much at all just like a half turn on them and they'll make all the noise int he world at idle. Anyways, if you look at the front of the transmission there's a lil metal plate there and bolts that go around it some small some big, just undo all those bolts and take that metal plate off, and then you'll be lookin at the flywheel or whatever automatics have and you might see one bolt lookin at it but there are 4 or 5 total, you'll need to put a big a** socket on the front of the engine to turn it don't know what its called but theres a bolt on a pully in the front of the engine all the way at the bottom, but you can turn that to turn the flywheel and torque converter to get to allt he bolts, and just tighten them up and then turn some more to get to the next one and tighten them up again, there are torque specs in a haynes manual for them and i tried my best to do that but there isn't really enough room to get a torque wrench in there(atleast not mine) so itried my best and they loosened again so i just went in and tightened them down real good and its been fine. but yeah just pull that plate off tighten those bolts put the plate back on and it should be good to go
2001 5.0 awd exploder - dd
$400 90 laredo xj - beater
91 Limited XJ - missed
Originally Posted by Centrax
There should be a warning label on the sun visor of those H2's "Warning, not intended for off road use." It's not even a REAL Humvee, it's just a Chevy Tahoe with fugly body panels.
thats hilarious
scubaguy19 is offline
post #8 of 13 Old 12-14-2004, 12:02 PM Thread Starter
BurlySurly
BurlySurly's Avatar
From the sound Im getting, I think that sounds pretty on- target with what's going on. I will give this a shot as well.
'93 XJ
4.0 Inline 6
2 Door
Automatic
post #9 of 13 Old 12-14-2004, 12:15 PM
xj4play
xj4play's Avatar
2004 KJ Liberty
If you decide to replace the TM, it is pretty easy and you don't have to drop the tranny to do it. On a side note, you don't have to drop the tranny to replace the rear main seal either.
I had the noise for a long time before I fixed the TM, I don't think you are going to encounter any major problems if you wait...
1998 ZJ Laredo
xj4play is offline
post #10 of 13 Old 12-14-2004, 12:24 PM Thread Starter
BurlySurly
BurlySurly's Avatar
Right on. Thanks.
I also just read that piece on replacing the rear main. Pretty easy job it looks like.
'93 XJ
4.0 Inline 6
2 Door
Automatic
post #11 of 13 Old 12-14-2004, 12:27 PM
xj4play
xj4play's Avatar
2004 KJ Liberty
Right on. Thanks.
Yeah, it shouldn't be too bad. I had it replaced when I first bought the Jeep 5 years ago, but now it needs replacing again. I figure I'll do it myself this time.
Do yourself a favor and get the one piece oil pan seal!
1998 ZJ Laredo
xj4play is offline
post #12 of 13 Old 02-07-2005, 01:53 PM
ZJ_COWBOY
ZJ_COWBOY's Avatar
1994 ZJ
It could be as simple at the exaust. Mine does it rerverse. Just try and put a shovel to the exaust and have some one see if it makes any sounds
RIP 93' ZJ
RIP 98' Dodge Neon
2001 Neon getting 30 MPG w00t!
94 ZJ $200 Project.
ZJ_COWBOY is offline
post #13 of 13 Old 02-07-2005, 02:28 PM
inkmonki
I Have Also Got This Problem
The Only Dif Is That Mine Is A 5 Speed And I Does Exactly As You Described. Give It Gas And Its Gone. Same Location Too. Thanks For The Problematic Ideas Im Having A Look At Them Theis Weekend Cause I Also Have Other Issues With My Tranny Right Now.
inkmonki is offline
death of an xj? PSUxjJeeper XJ/MJ Cherokee Non-Technical Forum 29 08-03-2009 09:12 PM
Death of a Xj wil badger XJ Cherokee Technical Forum 23 10-18-2006 08:21 AM
Death Rattle 4x4cherokee6 XJ Cherokee Technical Forum 7 02-19-2005 12:10 PM
Death Rattle of Death: Part Deux BurlySurly XJ Cherokee Technical Forum 3 01-11-2005 12:55 PM
New Cherokee owner - death rattle...how to deal?? ratter XJ Cherokee Technical Forum 7 09-24-2003 08:29 AM
