Dead Jeep even after replaced CPS and pick up sensor - JeepForum.com
post #1 of 6 Old 10-11-2009, 01:16 PM Thread Starter
broncofire75
Hey guys I swapped the CPS yesterday after my Jeep won't start
even with a new camshaft / pickup sensor and ended up putting the old pick up sensor back on and it cranked and ran fine. Drove it about 20 miles and now it's dead again. It started studdering on my way to a buddys house last
night and I made it but now it won't start.
CEL came on right before the studdering started back.
Any help? Any ideas?
-1998 XJ Sport 4.0L-
-6.5" RE/Rustys/RC lift, Custom Y-link LAs, custom shackle relocation boxes, Pro Comp/RE monos-
-315/75/16 Toyo MTs on Moabs-
-Shaved 8.25 w/HD shafts/Auburn LS/4:10s, HP30 w/ Lock-right, sliders, HD track bar bracket, AA SYE, AppA TC skid, AFE intake, Magnaflow exhaust, Bored TB-
broncofire75 is offline
post #2 of 6 Old 10-11-2009, 02:20 PM Thread Starter
broncofire75
Oh and I went and had the diagnostics clecked and it
came back as the pick-up sensor. It didn't work so I tried the CPS.
Anybody had the same problem?
post #3 of 6 Old 10-11-2009, 02:35 PM
xjfever
xjfever's Avatar
1995 XJ Cherokee
Could it be possible that the replacement cam sensor you got was bad? I have gotten a few bad sensors before.
xjfever is offline
post #4 of 6 Old 10-11-2009, 04:07 PM Thread Starter
broncofire75
Well the one I put in it to replace the stock one had a little different plug but it fit. It wouldn't start after I replaced so I changed the CPS. It did great. Now it's broke down again.
I'm gonna go get another cam sensor tomorrow and see if that's it. Idk
post #5 of 6 Old 10-13-2009, 05:03 PM
tjwalker
It's the crank sensor!
tjwalker's Avatar
Be sure that the "connectors" for both the cam and crank sensors are clean. If there is debris in the connectors, it creates a resistance path which can inhibit the signal from making it to the computer. A can of electrical contact cleaner is the ticket here....
Remember that there is also a connector for the crank sensor inside the engine bay near the firewall #6 injector. Unplug, clean, reassemble.
99 Cherokee, 4.0 AW4, NP242
Past Jeeps: 49 Willys, 81 Scrambler, 88 Comanche
Without "data", all you have is an opinion!
tjwalker is offline
post #6 of 6 Old 10-13-2009, 06:25 PM
malibill
possiable fix..
Hi, Bill here just went through the same thing replaced everything throttle body, crank sensor, fuel injectors, dist, coil ,fuel pump everything .. still crank but no start fuel at rail and spark at plugs.. drove me crazy try takeing out the front 02 sensor and see if it starts my cat was completly clogged solid .. Installed a new cat and front 02 sensor run`s like new.. hopefully this is what youre problem is..
malibill is offline
replaced crank sensor and still wont start wayneO XJ Cherokee Technical Forum 4 10-28-2013 08:31 AM
02 sensor replaced -- but recently running a little rough Koz83 XJ Cherokee Technical Forum 7 12-22-2009 05:05 PM
Replaced crankshaft sensor now dies when it comes to a stop XJoutlaw XJ Cherokee Technical Forum 13 11-12-2009 12:55 PM
Maintenance Req'd light went on, in my 91 Jeep Cherokee (I replaced the O2 sensor) norbyd XJ Cherokee Technical Forum 9 05-31-2009 05:34 PM
96XJ Fuel pump replaced. still dead. SIGman XJ Cherokee Technical Forum 12 03-25-2008 06:24 PM
