Hi,
I have the following problem on my wife's Cherokee (1991):
The low beam headlights and daytime running lights are not coming on. Both stopped working at the same time, so I do not think it is the bulbs. Side markers, High beam, indicator all work, so not a mass problem. switch checked out good. I do only have a very low voltage (about 0.2 volts) on the green wire driver side at the multi pole connector to the lights. It slightly changes with turning on the lights.
I have the suspicion that it is the DLR module. Any experience?
And where would I find this module?
Thanks for your input.
