dana 44 help - JeepForum.com
post #1 of 3 Old 06-23-2013, 03:02 PM Thread Starter
dkeller
dana 44 help
I was going to replace the pinion seal when I found that the yoke was tight when turned one way and sloppy when turned the other way.It felt tight when driveshaft was on. Should there be this much play in the pinion shaft? It actuall comes out a t bit and gets sloppy when turned in one direction.Incorrect preload? Shot pinion bearing?
http://www.youtube.com/watch?feature...&v=HCIP5BEbHUo
dkeller is offline
post #2 of 3 Old 06-23-2013, 08:21 PM
foggybottombob
There should be some rotational slack in a pinion but there should not be any in and out play at all.
foggybottombob is offline
post #3 of 3 Old 06-24-2013, 06:48 AM
wgirvine
1992 XJ Cherokee
Pinion bearings are shot. Replace.
The road goes on forever, the party never ends....
wgirvine is offline
