Dana 35, what parts to replace?? - JeepForum.com
post #1 of 5 Old 01-23-2013, 01:46 PM Thread Starter
CherokeeNZ10
So my currunt axle is making one hell of a grinding whining noise when driving after a little water got inside.
Do i get a new axle and bolt it in, done it before. Or replace the internals? If so what parts do i replace? do it myself?
I currently have heavyduty axle seals installed, can i reuse them?
HELP!! the noise is unbearable
CherokeeNZ10 is offline
post #2 of 5 Old 01-23-2013, 02:27 PM
1990JEEPXJ
1990JEEPXJ's Avatar
1990 XJ Cherokee
Get another bolt in axle and be done.
1990JEEPXJ is offline
post #3 of 5 Old 01-23-2013, 02:38 PM
GetLifted
Start with the shafts, carrier, gears, u bolts, and housing. Replace parts with a c8.25.
GetLifted is offline
post #4 of 5 Old 01-23-2013, 08:03 PM
JeepN4KC
Keep on Jeepin on........
JeepN4KC's Avatar
^^^ I thought the same thing when I clicked open the thread.
However - you can get a Super Dana35 which replaces the carrier with a Detroit and bigger diameter axle shafts w/o taper at the splines and I wanna say the spline count is 30.
~Mike~
WK
XJ
Sept '13/Jan '15/Jun '16 COTM
JeepN4KC is offline
post #5 of 5 Old 01-23-2013, 09:01 PM
xjfever
xjfever's Avatar
1995 XJ Cherokee
The cheapest fix will be replacing the entire axle with a newer 97-up 8.25. That is a nice upgrade from what you have.
xjfever is offline
