Dana 35 ABS replaced with Non-ABS - JeepForum.com
post #1 of 6 Old 06-11-2009, 02:29 PM Thread Starter
drespecki
1983 CJ7
1997 Cherokee with the Dana 35... Getting the grinding/noisy situation whenever accelerating, nothing when letting off on the gas.. Long story short, I got a 1996 Dana 35 form a cherokee and was going to swap it in but just noticed it has NO ABS!!! What can be done with it, what should I do? I can swap the axles easily but have no expertise doing the bad pinion bearing that seems to be making the noise..
Can I just disconnect the ABS system? The light will go on then and I don't want that.. ..
It only hurts while you're breathing..
drespecki is offline
post #2 of 6 Old 06-11-2009, 03:30 PM
the_weirdo
the_weirdo's Avatar
You can pull the ABS relays in the engine bay to make the ABS light go away.
the_weirdo is offline
post #3 of 6 Old 06-11-2009, 03:55 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
You can install the ABS on your "new" axle or, as noted above, just disconnect it.
CJ7-Tim is offline
post #4 of 6 Old 06-11-2009, 04:16 PM
sprintagogo
As already said you can swap the ABS onto the replacement axle but it will mean swapping the axle shafts over as the tone rings are fixed to these and I don't know if the non-ABS brake back plates will have all the holes needed for the sensors so it might be necessary to swap the back plates while the shafts are out.
Are you sure your new axle is the same gear ratio before you go to all this trouble?
Rollin on 32'zzzz
Originally Posted by Muddeprived View Post
Who's eric?
Originally Posted by HornedFrogHooah View Post
Sprintagogo, you're absolutely amazing. I don't care what they say about yall over across the pond - you're a godsend!
sprintagogo is offline
post #5 of 6 Old 06-11-2009, 04:57 PM Thread Starter
drespecki
1983 CJ7
The older axle without abs does not have the tone rings or the holes in the backer plates... looks like ABS kill time...
post #6 of 6 Old 06-11-2009, 05:02 PM
sprintagogo
WHY? It isn't a huge job to swap the ABS bits from your existing axle into the replacement one. Are you sure you can dissable the ABS and still pass inspection? Here in the UK if the components are present then they must function so the abs pump and sensors must be removed to get a pass.
Rollin on 32'zzzz
Who's eric?
What all should be replaced in old dana 44 before install. EdinMN XJ Cherokee Technical Forum 5 12-30-2009 12:48 AM
Replaced my RMS but never took the oil pan off.... Magus2727 XJ Cherokee Technical Forum 4 02-14-2009 08:09 PM
replaced the CPS.. ripcurl94 XJ Cherokee Technical Forum 11 07-23-2006 12:25 PM
Replaced just about everything and now I don't have spark? NewtooJeeps XJ Cherokee Technical Forum 11 11-21-2005 09:16 AM
Replaced Tie Rod Boots...NEED HELP! Rand McNally XJ Cherokee Technical Forum 10 04-04-2005 05:52 PM
