dana 30 upgrade - JeepForum.com
post #1 of 16 Old 12-25-2011, 06:40 PM Thread Starter
RED
dana 30 upgrade
ok so is there a axle that i can use to replace the ol 30? or some cheap shaft up grades? ive got a 99 xj but been thinking about doing a swap but need to keep it on the cheap side
RED is offline
post #2 of 16 Old 12-25-2011, 06:47 PM
Irongrave
cheep and axle swap very go hand in hand. keep it,
Current
2002 WJ 2wd DD
Irongrave is offline
post #3 of 16 Old 12-25-2011, 07:10 PM
Holder350
1995 XJ Cherokee
What are your plans for the jeep that make you want an axle swap?
The D30 can stand ALLOT of punishment....unless your planning on running anything over 35s locked it should fair pretty well.
I would suggest shaft upgrades and maybe a truss....but thats all I would do personally.
95' XJ Country - Stock Skids - D30/D35 Limited Slip - 3" Lift - 31x10.50R15 - 4.0 HO - AX15 - NP231
98' XJ Classic - D30/C8.25 - 4.5" RC Lift - 33x12.50R15 - 4.0 HO - AW4 - NP231
Originally Posted by Azzy View Post
You can tell the character of a person in how they treat someone who can do nothing for them.
Holder350 is offline
post #4 of 16 Old 12-25-2011, 08:19 PM Thread Starter
RED
well its a weekend toy it have 33 on it now but looking to doing a locker up front and new 33x13.50 tsl i just dont wanna snap a shaft in the woods also looking at doing 4.10 gears and super flex arms if i keep the 30 what shafts should i get?
RED is offline
post #5 of 16 Old 12-25-2011, 08:31 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Buy some chrome moly shafts, and keep and carry your stock shaft for trail spares.
CJ7-Tim is offline
post #6 of 16 Old 12-25-2011, 09:11 PM Thread Starter
RED
ok where do i find these shafts?
RED is offline
post #7 of 16 Old 12-25-2011, 09:21 PM
chriskeenan
most any 4wd vendor will stock them.
Also the new "cool" things are the RVC shafts, supposed to be even stronger than the normal chromoly shafts. though one down side to strong shafts and u-joints is that then the ring and pinion are now the weak point, grenading one of those is not pretty.
chriskeenan is offline
post #8 of 16 Old 12-25-2011, 09:22 PM
CJ7-Tim
CJ7-Tim's Avatar
On the InterGooglewebz
CJ7-Tim is offline
post #9 of 16 Old 12-25-2011, 09:32 PM Thread Starter
RED
ok ima look now and what about tranny mods? ima do a temp gauge and coolers but really wanna wire it up for the 1st gear mod but only seeing it for the older jeeps
RED is offline
post #10 of 16 Old 12-25-2011, 10:21 PM
chriskeenan
It can be done on newer OBD2 XJs just the same but it will trigger the CEL. Montana Auto Fab has a setup they claim doesn't trigger the CEL, it uses some resistors to put a dummy load on the solenoid drivers and adjusts the MAP sensor output IIRC. I'm working on a plan of my own to allow full manual control of the AW4 and still retain the auto function w/o CEL, but its just a plan so far.
post #11 of 16 Old 12-26-2011, 12:40 AM
Timo_90xj
Timo_90xj's Avatar
Keeping the lever in 1-2 you won't be seeing 2nd gear too often. Only shifts closer to redline. I can't remember too many times I've gotten headache with 1-2 or 2-1 shifts when on the trails. IMO not the most important mod, but. Sure is handy at times
***Under construction***
Timo_90xj is offline
post #12 of 16 Old 12-26-2011, 12:51 AM
SCchillipepper
If hes got a 98 then its a lp d30 so a hp d30 from an older Cherokee (before 97) and some shafts and its good to 35s and look at RADesigns Products there stuff is sweet and dose wat you and chriskeenan want it to do.
Its 100 bucks for a complete phd30 from my local pap.
1998 TJ 35's Metalcloak Front Fenders 3" Currie Springs 4.88 Spartan Rear D44 front HPD30 under construction.
SCchillipepper is offline
post #13 of 16 Old 12-26-2011, 01:02 AM
Timo_90xj
Timo_90xj's Avatar
Originally Posted by SCchillipepper View Post
If hes got a 98 then its a lp d30 so a hp d30 from an older Cherokee (before 97) and some shafts and its good to 35s...
Wrong info there my friend.. Only the '00-'01 XJs use an LPD30. All others are high pinion.
For the OPs cheap front axle upgrades, I agree with others that he's pretty much limited to cromo- shafts. Even a truss can become suprisingly expensive with all the fab & weld work if he hasn't got the tools for the job.
post #14 of 16 Old 12-26-2011, 10:02 AM Thread Starter
RED
well ive got the tools just dont wanna spend a whole lot of cash on this toy a cel idc lol it stays on anyways ive got 1100 bucks in this jeep so i dont mind to spend the money but only if its worth it know what i mean! but so far she has been a champ ive lanched it up hills and raced down trails knock on wood nothing broken but i know something will break and when it does i wanna be ready! now one more question i bought a 99 xj with factory sucurity system it came with no keys as i got it from a junk yard so i just changed the ingnion with a autozone and it starts but runs for 5 seconds then dies every time how can i by pass this and get my junk yard jewell driveable?
RED is offline
post #15 of 16 Old 12-26-2011, 10:15 AM
chriskeenan
You either need to talk with the dealer about getting new SKIS keys made, or you have to remove the SKIS ignition module and replace the ECM with one that does not have the SKIS system setup. AFIK there is no way to undo the SKIS install on the ECM, it has to be replaced.
Dana 30 upgrade questions CallMeColt XJ Cherokee Technical Forum 30 08-01-2011 07:11 AM
Whats the best hub upgrade for the dana 30? spaz1433 XJ Cherokee Technical Forum 3 08-17-2009 07:22 AM
Dana 30 upgrade jeeper01 XJ Cherokee Technical Forum 8 07-13-2006 02:45 AM
Dana 30 upgrade gumcrew2 XJ Cherokee Technical Forum 17 04-14-2006 12:01 AM
Dana 44 upgrade kowalsy XJ Cherokee Technical Forum 7 02-08-2005 02:57 PM
