Dana 30 high pinion vs low pinion
| Truck-Lite's New LED Headlamp Series | GR8TOPS Introduces the Exogate HD Tire Carrier | RUBICON EXPRESS Lift Kits and Accessories Available at Bas |
#1 | |
Well the 00-01 have low pinion D30 in the front. What does that mean? and is better then the high pinion?
[I]00' XJ Sport. 4.0 I6. [B]|15" Canyon Crawlers | 30x9.5 Bridgestone Dueler A/T Revos | [Lifted (2" Teraflex Spacers | 2.5" RE AAL | Edlebrocks IAS)| K&N Homebrew Intake | Flow Master 70 |Clear Corners/Side Markers| Class III Hidden Hitch | C4x4 Fronts Tow Hooks | JKS Discos | Surco Safari Rack | Hella 500s | |
#2 |
Mumbling Jeeper
I know, rather I think, for the most part it just refers to the fact that the high pinion differential housing actually sits higher on the axle than the low pinion. So in essence, you have slightly more clearance in the high rather than low pinion. I'm pretty sure the spline count, ring gear, and shaft diameters are the same. The U-Joints may be different based upon year.
#3 |
High pinion, the drive shaft comes in on the top half of the differential, giving better clearance.
2004 Jeep Wrangler Unlimited, Automatic RC 2.5" Lift - RC 2.5" Rear Track Bar Bracket - JKS 1.25" Body Lift - JKS Front Disconnects - JKS 1" Budget Motor Mount Lift - Spidertrax 1.25" Spacers - Power Door Locks with Keyless Entry Build Project Thread Rocker Guard Comparison Chart - Final Differential Gear Ratios - Oxygen Sensor FAQ |
#4 | |
Mumbling Jeeper
#6 | |
#7 |
The high-pinion version also has reverse-cut gears which are slightly stronger.
#8 | |
The Post man
High-pinion is preferable for several reasons. First is driveshaft clearance. With a HP axle, the driveshaft is a good 2 or 3 inches higher up than the LP. That could very well be the determining factor on whether or not your driveshaft survives a rock. Second is driveshaft angle. A higher pinion gives you a much better driveshaft angle and this means less chance of vibration on a lifted XJ. Third is strength. The ring and pinion on a HP axle is slightly stronger than on the LP. That being said, lots of people use the LP Dana 30 without problems. Its the same axle used in the TJs. If you are going to lift it above 5" I think it would be a very good idea to look for a HP, or if you ever just have a good opportunity to get one. Make sure you have at least some lift however or the driveshaft might make contact with your exhaust.
Eric 2000 XJ "PROJECT RUBICON" lifted, locked, shafted, running 35's, 4.56 gears, pair of ARB's, and stock AM/FM cassette My website - EricsXJ.com
#9 |
Like Eric said the only real difference is in where the pinion is in relation to the centerline of the axle. As for which is stronger HP or LP diffs... this debate will rage for yrs. The ring gear is the only thing that is not interchangeable between the 2. Carriers, axle shafts, knuckles are all the same. Install kits are different as well
90 Comanche thing. Exo-cage, tube bed, with a few other things done Here is a link to some pics of it [url]http://independent4x.com/generic67.html[/url] [url]http://community.webshots.com/user/cj7xjmj[/url] If you have to ask why... Its a truggy thing and you wouldn't understand |
#10 |
Yeap I've had a 2000 (lp d30) lifted with a Rustys 4.5" and I got vibes up front when in 4wd because of the pinion angle.
I now have a '99 (HP d30) and RE 4.5" and no vibes at all ever.
[B]CANCER AND LUEKEMIA SUCK[/B] Proud to be a Christian |
#11 | |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
