Daily Driver XJ, and a front locker(lock-right) - JeepForum.com
post #1 of 24 Old 03-06-2010, 03:46 PM Thread Starter
XJ Jay
first off i KNOW you can not run a full locker or spool in a non disco front diff, and i understand why (im a journeymen auto tech). and i know your not saposta run a ratchet style locker in the front in a daily driver as well. but i ask who has actually run a ratchet style locker in the front. what was the long term out come (worn splines on the axle/locker). the detriot true-trac isnt quite what im looking for(cost and performance wise) ive read a few guys on NAXJA have run a lock-right in the front in there daily, but didnt mention of any lock term side affects. i never use my 4x4 on dry pavement, only icy,snowy,slushy roads or when i wheel. i have stock gears(3.54) and dont plan on going bigger then my 31s or re gearing
HISWhite 99 XJ Sport
5" RC/ProComp lift, Serious long arms, 33" Cooper STTs, Soft 8s, 4.56s, Aussie locked D30, LSD 8.25,discos, armoured blah blah blah, HP44/9" coming soon
HERSBlack 08 JK Unlimited X, Teraflex 1.5" leveling kit, Rubi coils 35" TSRs and 5.13s
XJ Jay is offline
post #2 of 24 Old 03-06-2010, 03:52 PM
xjfever
xjfever's Avatar
1995 XJ Cherokee
There is absolutely nothing wrong with running a lunchbox/auto locker in the front with a non disco unit. The locker only works when power is applied to the front axle as in when the jeep is in 4wd. There are no ill affects in running one up front.
xjfever is offline
post #3 of 24 Old 03-07-2010, 09:19 AM Thread Starter
XJ Jay
thank you!, but why to they call it a lunch box
XJ Jay is offline
post #4 of 24 Old 03-07-2010, 09:50 AM
xjfever
xjfever's Avatar
1995 XJ Cherokee
Not really sure I can answer that, but it just replaces the spider gears instead of the complete carrier. They can be installed in your driveway without any special tools.
xjfever is offline
post #5 of 24 Old 03-07-2010, 10:47 AM Thread Starter
XJ Jay
yeah i know how they work and install. i however am blessed with a 8 bay auto repair shop at my disposal, so no drive way installs for me.
XJ Jay is offline
post #6 of 24 Old 03-07-2010, 10:47 AM
Project1
Is it a problem to use a locker in the rear axle of a daily driver?
Project1 is offline
post #7 of 24 Old 03-07-2010, 11:34 AM Thread Starter
XJ Jay
how the hell am i ever gonna get my hotrod back on the road if i keep dumping money in my jeep. i plan to finish my car this summer, but its hard when there so much i want to buy for my jeep. ahhhhh two project vehicles! i think im sold on the aussie VS the lock right
XJ Jay is offline
post #8 of 24 Old 03-07-2010, 11:44 AM
xjfever
xjfever's Avatar
1995 XJ Cherokee
No lots of people do it, esp. with you living in florida where you will not be driving in snow and ice. The only drawback will be some popping and clicking when making turns while accelerating.
xjfever is offline
post #9 of 24 Old 03-07-2010, 12:03 PM
Project1
Thanks for the advice. Lockers is comming up close on my list of things to get. I keep buying parts but have not put any of them in. I'm just wait to get a good build thread going
Project1 is offline
post #10 of 24 Old 03-07-2010, 12:08 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
You can search for the front vs rear locker arguments and decide for yourself where to install one.
A locker in the rear axle behaves on pavement in a similar manner to the Trac-Loc Limited Slip that has been a factory option in Jeep for 40+ years. I have had a rear locker in my 2000 for years, and it replaced the original Limited Slip. My front axle locker does nothing in 2wd, in 4wd and MN snow, it does make the front tires push straight a little bit in turns.
CJ7-Tim is offline
post #11 of 24 Old 03-07-2010, 12:17 PM
Project1
I think locking both sounds like the way to go.
Project1 is offline
post #12 of 24 Old 03-07-2010, 12:38 PM
Kevin108
Because it packs inside of your existing carrier.
Not at all as long as you drive appropriately. You learn to power on heavy then coast through turns. I have the Aussie and I've found that even under idle and light power, the locker is still able to unlock so parking lots and other low-speed/tight turn scenarios aren't a problem.
Typically the people that say lockers are iffy on snow and ice either don't have a locker or have never driven with one on snow and ice and are just repeating what they've read here on the interwebs. My area had more snow this year than in the last 20 years or so. I drove quite a bit for work and fun and I can say that unless you're driving like an idiot, you won't have any problems. Also, unless you're driving like an idiot, the extra traction helps a lot. If you listen closely, you can hear the ratcheting sound during turns when the locker is unlocked. If you're hearing popping and clicking, ease up on the throttle Dale Earnhardt.
I don't have a front locker but the only downside I can see to this setup is heavier steering when offroad. If you and your steering gear box can handle that, I say go for it! Look below for what front and rear locker (along with a little armor and a tiny lift) can do.
My build thread has pics again. http://www.jeepforum.com/forum/f177/kevin108s-2000-xj-build-867428/
Kevin108 is offline
post #13 of 24 Old 03-07-2010, 03:23 PM
brian0128
Damn, I wouldn't have even attempted that hill!
brian0128 is offline
post #14 of 24 Old 03-07-2010, 03:46 PM
Project1
Crazy video man !
Thats an awesome cj too !!!
Project1 is offline
post #15 of 24 Old 03-07-2010, 04:07 PM
xjfever
xjfever's Avatar
1995 XJ Cherokee
I live in the mountains where a lot of turns are out of steep driveways, or from a steep road onto another road. It is very hard to turn out without using the accelerator and you will get some clicking and popping in this situation. I don't drive like an idiot, or think I am dale earnheardt. It is just a side affect of having a rear locker and making uphill turns. I didn't mean to imply it was a loud banging or anything, just a normal affect of having a rear locker. And when the roads are icy in those same situations both rear tires will spin and the vehicle will want to slide toward the downhill side. I have had several jeeps with auto and selectable lockers in the front and rear so I am not repeating what I heard some 18 year old say on the internet.
xjfever is offline
lock right locker in front dana 30 on my xj ruegergage XJ Cherokee Technical Forum 25 08-24-2010 11:38 PM
Lock Right locker+36s in front? xj97jks XJ/MJ Cherokee Non-Technical Forum 21 10-28-2009 02:07 PM
Front Locker Choice: Aussie or Lock-Right dudeinajp XJ Cherokee Technical Forum 19 05-31-2008 06:33 AM
can this be used as a daily driver whitemonster XJ Cherokee Technical Forum 48 01-30-2007 10:32 AM
Front locker in a daily driver? non-disconnect BeJay1981 XJ Cherokee Technical Forum 3 03-22-2005 03:28 PM
