d44 and d60 - JeepForum.com
post #1 of 14 Old 12-05-2007, 08:35 PM Thread Starter
lifted92xj
lifted92xj's Avatar
1992 XJ Cherokee
d44 and d60
so after going through an axle shaft and having my hub break apart yesterday i want to upgrade the axles. a buddy of mine has a front d44 and a rear d60 im wondering whose done either one of those swaps and how hard they were
big lift, sick tires, awsome accessories, alot of custom work.
my jeep won the war, your honda mows my lawn
lifted92xj is offline
post #2 of 14 Old 12-05-2007, 08:47 PM
ktmracer419
ktmracer419's Avatar
1997 XJ Cherokee
can you research?
can you set up gears?
can you measure?
can you cut?
can you weld?
ktmracer419 is offline
post #3 of 14 Old 12-05-2007, 08:47 PM
balloo93
Little Red Menace
balloo93's Avatar
1993 XJ Cherokee
What D44 front? If its' the Ford HP D44 it's been done and there's a short cut for getting the brackets on.
The D60 hangs LOW.
93 Sport
Beer is proof that God loves us and wants us to be happy............Ben Franklin
Specs in Profile.
balloo93 is offline
post #4 of 14 Old 12-05-2007, 09:08 PM
ktmracer419
1997 XJ Cherokee
The D60 hangs LOW.
might be different for full floaters but my dana 60-2 hangs down a tad over 1/2" as compared to my 44.
even if i measured wrong, i seem to drag my diff on the same rocks as i have my old 44
97 xj
44 front, detroit, alloyed
60 rear, detroit, 35 spline alloyed
35" beadlocked km2's
3" midarmed
more bells and whistles than you can shake a stick at
post #5 of 14 Old 12-05-2007, 09:35 PM
Sierra Drifter
If you're going to go through all the work and expense of swaping both axles then you might as well get a Ford high pinion front D44, and be prepared to spend a fair amount of money.
2001 XJ RE 5.5 ED w/T&T Y-link longarm, 37" MTR's, D44/D60, ARB's, Rubicon Tcase, and all the usual junk.
Axle swaps & build thread:
Sierra Drifter is offline
post #6 of 14 Old 12-05-2007, 09:37 PM
Sierra Drifter
Yep, I have 11 3/4 inches from the pavement to the bottom of my front D44, and 11 1/8 inches at the D60 rear. Not really that much of a difference.
post #7 of 14 Old 12-05-2007, 10:26 PM
balloo93
Little Red Menace
balloo93's Avatar
1993 XJ Cherokee
Is there a difference in the housing size between a FF and the SF D60s out there?
93 Sport
Specs in Profile.
balloo93 is offline
post #8 of 14 Old 12-06-2007, 08:10 AM Thread Starter
lifted92xj
lifted92xj's Avatar
1992 XJ Cherokee
yeah i can cut weld and all of that stuff..im getting surgery on my knee and will be out of school for 4-6 weeks and i think this is the project i want to do..i want to attempt the soft top but this is much easier to get out of if i do something wrong
post #9 of 14 Old 12-06-2007, 01:26 PM
ChewyXJ
nom nom nom
ChewyXJ's Avatar
It may not seem like much but 5/8" of clearance can be the difference in making a line or getting hung up.
Weight is another consideration in the d60 vs d44 decision.
I wouldn't use a D60 unless my tires are over 36" (or you wheel like a maniac)and I planned on doing a fair amount of strengthening to the unibody.
'93 Cherokee Sport 4.0 man. 4.5" Black Diamond/ O.M.E., JKS control arms, discos, track bar, rear D44/detroit, 35x12.5 BFGmt's,33x13.5 LTBs,AlloyUSA shafts, oba, Warn M8000 multi-mount
'97 Cherokee Sport 5spd,231, white, stock
'90 Cherokee Pioneer 4.0 auto, 6" homebrew long arm lift, 33x10.5 BFG MT's, etc.
'87 XJ 2" lift
'96 XJ stock
"Personally, I've learned so much from my mistakes, I'm thinking of making some more."
"Don't believe everything you think..."
ChewyXJ is offline
post #10 of 14 Old 12-06-2007, 02:28 PM
ktmracer419
1997 XJ Cherokee
5/8" doesn't seem like alot when im wheeling.
with all 4 tires turning, chances are one of those tires is gonna want to pull your ramp-shaped differential over that rock that's 5/8" too tall.
97 xj
3" midarmed
post #11 of 14 Old 12-06-2007, 04:41 PM
ChiliPalmer
This is Ames Mister...
ChiliPalmer's Avatar
That's if you shave it, unshaved it will get hung up...
If you want to help the sport of offroading visit the
Forum!
Oh man Chili. I feel like a recovering addict that just had a bag of blow, a bottle of Jameson, and a sack dropped in his lap. You screwed me man!
ChiliPalmer is offline
post #12 of 14 Old 12-08-2007, 09:13 PM
XjKid95
Is it possible to adapted a tj or other jeep front diff to my xj. How difficult is it?
XjKid95 is offline
post #13 of 14 Old 12-08-2007, 09:21 PM
XJohnnyC
XJohnnyC's Avatar
Hey XjKid95
You have a PM.
XJohnnyC is offline
post #14 of 14 Old 12-08-2007, 09:27 PM
XjKid95
On the site or like instant messager
XjKid95 is offline
