D35 popping around turns - JeepForum.com
post #1 of 5 Old 07-20-2011, 01:19 PM Thread Starter
wheelin_the_XJ
1990 XJ Cherokee
as the title says my d35 non c-clip is popping when i turn sharply. it is locked with a detroit locker and has 3.83 gears im also running 33 inch tires. just to let yall know. i was thinking it could be the axle shafts as it only does it when there is stress on the rear end like turning real sharp on the road. it doesnt do it offroad. if it is the axle shafts how do i replace them? and is there any upgraded ones i should try to get. and also is this a do it yourself job? thanks in advance
wheelin_the_XJ is offline
post #2 of 5 Old 07-20-2011, 02:00 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
If the locker is in proper working condition, clicking and popping should be considered "normal". Make sure to keep your tire pressures the same on the locked axle.
If you think the problem is caused by the axle shafts, you should inspect them for unusual wear or damage.
CJ7-Tim is offline
post #3 of 5 Old 07-20-2011, 03:57 PM Thread Starter
wheelin_the_XJ
1990 XJ Cherokee
how do you inspect the axle shafts? and the rear end is completely locked no give what so ever. im not sure if its suppose to be like that as i bought the jeep with the locker in the rear
post #4 of 5 Old 07-20-2011, 04:29 PM
Luke94XJ
1994 XJ Cherokee
I'd open it up to make sure that the thing wasn't just Lincoln locked.
Luke94XJ is offline
post #5 of 5 Old 07-20-2011, 05:31 PM
CJ7-Tim
CJ7-Tim's Avatar
Use your Google-Fu and find the instructions for your locker. They will explain the installation and testing procedures.
If you have a local 4x4 shop, you should go see them first.
CJ7-Tim is offline
axle , axle shaft , d35 , popping , shaft
Popping crunching metal on metal sound from rear end on slow turns after driving KariGrrrl XJ Cherokee Technical Forum 6 09-26-2010 05:51 PM
Popping noise when steering wheel turns cherokeekid58 XJ Cherokee Technical Forum 6 07-22-2010 04:19 PM
Car only turns right. BunnyHunterOG XJ Cherokee Technical Forum 62 02-27-2009 02:49 PM
"popping noise" on turns delichani XJ Cherokee Technical Forum 6 07-12-2005 04:44 PM
Turns out wasn't TPS JeffR XJ Cherokee Technical Forum 4 02-01-2004 07:31 AM
