D30 disconnect to single piece axleshaft, seal questions - JeepForum.com
post #1 of 3 Old 12-18-2008, 04:52 PM Thread Starter
mattbred
1989 XJ Cherokee
I'm going to convert my vacuum disconnect dana-30 in my '89 to a single piece shaft, like the later models. However.. Can I simply re-use the seals that are originally used on the '89? I've heard that you can buy an axle seal for a later model, grind down the surface and then install it, but I'd rather not take the carrier out. Is it possible to simply take out the two piece axle shaft, and insert the one piece without changing any seals whatsoever, or do they have different diameters?
mattbred is offline
post #2 of 3 Old 01-11-2009, 05:02 PM
jeepnatv4life
Bump id like to no this
XJ 35's locked Gas Tank in the Trunk Shox Hoops in the rear.
'13 RZR 570
jeepnatv4life is offline
post #3 of 3 Old 01-11-2009, 05:41 PM
xjfever
xjfever's Avatar
1995 XJ Cherokee
http://www.stu-offroad.com/axle/yjd3...jconvert-1.htm This should help.
xjfever is offline
sway bar disconnect questions bingolli XJ Cherokee Technical Forum 2 09-08-2008 11:46 AM
New Exhaust questions. Single vs Dual Bodybuilder21 XJ Cherokee Technical Forum 6 07-01-2007 01:06 PM
single, single 1.5 or double din for the radio? CherokeeClassic XJ Cherokee Technical Forum 9 07-10-2006 10:46 PM
90 xj one piece rear main seal? not two? gbaronetXCR XJ Cherokee Technical Forum 4 05-06-2005 09:36 PM
Rear Main Seal and One Piece Pan Gasket xj4play XJ Cherokee Technical Forum 1 12-03-2004 02:41 PM
