12-01-2006, 09:39 PM
#1
for those of you that had cylinder head casting #0331 crack, did you just go for another reman. one? the guy i was gonna buy a new aftermarket one ran out and doesnt know when he'll get them back in stock. so does anybody know of any other new aftermarket heads? i really dont want to buy a reman. one
2011 Wrangler Unlimited Rubicon- Flame Red
1999 Grand Cherokee Limited
God Bless All The Men And Women Who Served And/Or Is Serving This Great Country!
Proud To Be A FF/EMT/Police/Military Club Member #3
12-02-2006, 07:02 AM
#2
Go for a remain head, yes. But go for a head from a slightly older HO engine. I cannot remember the casting number for the previous version (up through about 98), but that's the one you should ask for.
AZ-Jeff
1992 XJ 2" lift -- RIP
2000 XJ 3" lift -- Australian Ford Big Brakes up front, rock rails, ZJ rear discs (with WORKING parking brake), C4x4 rear bumper/tire carrier, Hella H4 headlights, IPF driving lights, OEM skid plates, OME springs/shocks, JKS LCA's, JKS Sway Bar links.
12-02-2006, 07:55 AM
#3
where is this casting #? I am looking at a 01 Cherokee and was warned about these heads, I looked on the passenger side of the head and couldn't seem to find it.
12-02-2006, 09:45 AM
#4
the casting number on mine was only visable once i pulled off the valve cover
so your saying that i dont need to get the same casting number on the head, a different head will still work?
12-02-2006, 10:01 AM
#5
any body know if a head from a '98-'99 will work as a replacement for the cracked one on my 2000?
thanks
12-02-2006, 12:20 PM
#6
thanks
I am about 95% certain the head you want is the 97-98 head, which has the same geometry as the 2000 head, without the casting flaw.
Go over to Jeeps Unlimited, and find a guy over there who goes by the name of Dino Saava. He is the guru on engine parts interchange on the 4.0, and can confirm this.
AZ-Jeff
12-02-2006, 02:57 PM
#7
get a 98 head..it has bigger exhaust valves then the 99'+ heads
1999 Cherokee Classic: R.I.P. http://www.cardomain.com/ride/2313036
2001 Cherokee Limited My Build Thread: 6" IRO Long Arms and coils, JKS ACOS, IRO 5.5" Leaf Springs, Liquid Iron Industries Slider Boxes, 35x12.50 Goodyear MTR/K, RC Quick Discos, Fox 2.0 IPF Shocks, Rear Disk Brakes, WJ Brakes and steering, JCR Rock Sliders, 60mm Bored TB, Cobra Injectors, Rugged Ridge Header, 2.5" Exhaust with Borla Muffler
12-03-2006, 05:44 PM
#8
well i found an aftermarket cylinder head that replaced the #0331 casting from a company called clearwater cylinder heads. they said that the new head is made from a stronger material and is reinforced at the weak points. it set me back $440 but it's a brand new head complete with new valves, springs, and retainers already assembled. all the reman. heads i looked at were between 350-385 so for the extra bit i get some peace of mind. i'll post pics and an update when it arrives and my front door.
