cylinder compression technical question. - JeepForum.com
post #1 of 4 Old 08-12-2002, 06:13 AM Thread Starter
jaybyrd
jaybyrd's Avatar
Question cylinder compression technical question.
According to the haynes manual if cylinder 1 has low compression and the rest are o.k. then problem is likely a worn exhaust lobe on the cam shaft.
1988 Cherokee Laredo inline 6 4.0L 5 speed manual.
The question I have is this: Could I adjust the pushrods at the #1 cylinder to compensate for the wear on the exhaust lobe to give more range of motion to the cylinder?
Any ideas or fixes would be appreciated..
jaybyrd is offline
post #2 of 4 Old 08-12-2002, 09:02 PM
Tomguy
2014 WK
Well, (I believe) the engine has overhead cams, so it wouldnt have a pushrod. But yes, you can. When I rebuilt the engine on a truck I play around with, I loosened the nuts, took the worm screws down to the thickness of an index card (at closed valve), and tightened the nuts back up, and it quieted the valve tapping too. I'm thinking of doing it on my Cherokee.
Hemi, Towing & Lux
198k
Previous: 1972 Benz 280SE 4.5, 1992 XJ Cherokee Laredo, 2006 Charger R/T
Tomguy is offline
post #3 of 4 Old 08-13-2002, 09:11 PM
Flanz
I have never opened my engine up but I know they sell pushrods for the 4.0.
'88 XJ 4.0L Rusty's cat back exhaust with Flowmaster
Flanz is offline
post #4 of 4 Old 08-13-2002, 09:52 PM
arpy
4.0 is not an overhead cam engine, definitely has pushrods.
The new series of engines in the Grand Cherokee are overhead cam, but not the 4.0.
arpy is offline
Low compression in one cylinder. Lone Star XJ XJ Cherokee Technical Forum 6 09-28-2010 09:15 AM
Technical question about cluster Probie101 XJ Cherokee Technical Forum 3 01-20-2009 07:05 PM
Technical Lift Question onlyinajeep07 XJ Cherokee Technical Forum 3 04-15-2007 11:11 AM
Not so technical question bluesman905 XJ Cherokee Technical Forum 10 03-18-2006 09:03 AM
Low compression one cylinder? jaybyrd XJ Cherokee Technical Forum 1 08-15-2002 06:50 PM
