cv driveshaft length - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > cv driveshaft length
CHASSIS SAVER™ Rust Preventive Paint Memorial Day Weekend RuffStuff Memorial Day Sale!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 09-03-2005, 01:41 PM   #1
ktmracer419
1997 XJ Cherokee
what lengthcv driveshaft will i need?
4.0,aw4,np231, chrysler 8.25
about 4-5" lift
extended length/closed lenth
thanks in advance
-sam
97 xj
44 front, detroit, alloyed
60 rear, detroit, 35 spline alloyed
35" beadlocked km2's
3" midarmed
more bells and whistles than you can shake a stick at
ktmracer419 is offline   Reply With Quote
Unread 09-03-2005, 02:18 PM   #2
gwarusee
I have a closed length of 33" on my spicer flange style shaft. I am running about 5.5 " of lift. If your ordering the shaft from a distributer ( high angle, spicer, RE, tom woods etc..) they will know exactly what you need if you give them the info you posted.
gwarusee is offline   Reply With Quote
Unread 09-03-2005, 02:20 PM   #3
wes19d
You will have to measure that yourself, get the jeep on some level ground, and measure from the center of the U Joint on the TC slip yoke to the u joint on the rear, and you should have a pretty accurate measurment.
05 RUBI
wes19d is offline   Reply With Quote
Unread 09-04-2005, 10:09 AM   #4
Sierra Drifter
about 4-5" lift
thanks in advance
-sam
You didn't mention if you are going to run an SYE.
I used to have the same 4.0, aw4, np231, chrysler 8.25, with a 5.5" lift and an RE Hack-n-tap SYE and my shaft was 33 1/2". I measured from the flat flange on the SYE to the center for the ujoint and then ordered the shaft from RE.
2001 XJ RE 5.5 ED w/T&T Y-link longarm, 37" MTR's, D44/D60, ARB's, Rubicon Tcase, and all the usual junk.
Axle swaps & build thread: http://www.jeepforum.com/forum/f11/rebuilding-front-dana-44-a-397243/
Sierra Drifter is offline   Reply With Quote
